[PROJ] How does proj deal with ellipsoid with respect to reprojection
Even Rouault even.rouault at spatialys.com
Sat Mar 28 08:30:43 PDT 2020
Brendan,
> Or does the fact
> that my source and target ellipse/datum are the same mean the gnomonic
> projection has the WGS4 coordinates passed directly to it?
Yes, given that the source and target datums are the same, no change in geographic
coordinate is done.
And given that the implementation of gnomonic is for a sphere only, the flattening
of WGS84 is ignored. So you'll get the same result as if it was a sphere of radius
6378137 metres
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200328/fbbbbbcb/attachment.html>
More information about the PROJ mailing list
