[PROJ] PROJ 7.0.1RC1 & 6.3.2RC1
Kristian Evers kreve at sdfe.dk
Fri May 1 01:27:14 PDT 2020
Motion passed with +1’s from Kristian, Even, Howard and Thomas.
The final releases will be available soon.
/Kristian
Sent: 30. april 2020 17:32
To: Kristian Evers <kreve at sdfe.dk>
Cc: Kristian Evers <kristianevers at gmail.com>; PROJ <proj at lists.osgeo.org>
Subject: Re: [PROJ] PROJ 7.0.1RC1 & 6.3.2RC1
+1 Thomas
Den tor. 30. apr. 2020 kl. 11.23 skrev Kristian Evers <kreve at sdfe.dk<mailto:kreve at sdfe.dk>>:
With the exception of a few minor warnings in 6.3.2RC1 reported by Greg,
no serious problems have been found in the two release candidates.
So, I hereby motion that we promote proj-7.0.1RC1 and proj-6.3.2RC1 to their final
versions.
I’ll start with my +1
/Kristian
-----Original Message-----
From: PROJ <proj-bounces at lists.osgeo.org<mailto:proj-bounces at lists.osgeo.org>> On Behalf Of Kristian Evers
Sent: 27. april 2020 11:23
To: PROJ <proj at lists.osgeo.org<mailto:proj at lists.osgeo.org>>
Subject: [PROJ] PROJ 7.0.1RC1 & 6.3.2RC1
All,
With scheduled releases of PROJ 7.0.1 and 6.3.2. on May 1st it is time
to put out release candidates. Both candidates includes a number of bug
fixes since the previous release. 7.0.1 includes 39 bug fixes and 16 bugs
has been fixed in 6.3.2. See the release notes below.
Archives are available here:
http://download.osgeo.org/proj/proj-7.0.1RC1.tar.gz
http://download.osgeo.org/proj/proj-7.0.1RC1.zip
http://download.osgeo.org/proj/proj-6.3.2RC1.tar.gz
http://download.osgeo.org/proj/proj-6.3.2RC1.zip
Please test the release candidates and report back any problems you
may encounter.
If no issues are found with the two release candidates the final releases
will be announced on Friday May 1st.
/Kristian
7.0.1 Release Notes
 Updates
 o Database: update to EPSG v9.8.9 #2141
 Bug fixes
 o Make tests independent of proj-datumgrid (#1995)
 o Add missing projection property tables (#1996)
 o Avoid crash when running against SQLite3 binary built with
   -DSQLITE_OMIT_AUTOINIT (#1999)
 o createOperations(): fix wrong pipeline generation with CRS that has +nadgrids=
   and +pm= (#2002)
 o Fix bad copy&replace pattern on HEALPix and rHEALPix projection names (#2007)
 o createUnitOfMeasure(): use full double resolution for the conversion
   factor (#2014)
 o Update README with info on PROJ-data (#2015)
 o utm/ups: make sure to set errno to PJD_ERR_ELLIPSOID_USE_REQUIRED if
   es==0 (#2045)
 o data/Makefile.am: remove bashism (#2048)
 o ProjectedCRS::identify(): tune it to better work with ESRI WKT
   representation of EPSG:2193 (#2059)
 o Fix build with gcc 4.8.5 (#2066)
 o Autotools/pkg-conf: Define datarootdir (#2069)
 o cs2cs: don't require +to for '{source_crs} {target_crs} filename...'
   syntax (#2081)
 o CMake: fix bug with find_package(PROJ) with macOS (#2082)
 o ESRI WKT import / identification: special case for
   NAD_1983_HARN_StatePlane_Colorado_North_FIPS_0501 with Foot_US unit (#2088)
   NAD_1983_HARN_StatePlane_Colorado_North_FIPS_0501 with Foot_US unit (#2089)
 o EngineeringCRS: when exporting to WKT1_GDAL, output unit and axis (#2092)
 o Use jtsk03-jtsk horizontal grid from CDN (#2098)
 o CMake: prefer to use use PROJ_SOURCE_DIR and PROJ_BINARY_DIR (#2100)
 o Fix wrong grids file name in esri.sql (#2104)
 o Fix identification of projected CRS whose name is close but not strictly
   equal to a ESRI alias (#2106)
 o Fix working of Helmert transform between the horizontal part of
   2 compoundCRS (#2111)
 o Database: fix registration of custom entries of grid_transformation_custom.sql
   for geoid grids (#2114)
 o ESRI_WKT ingestion: make sure to identify to non-deprecated EPSG entry when
   possible (#2119)
 o Make sure that importing a Projected 3D CRS from WKT:2019 keeps the base
   geographic CRS as 3D (#2125)
 o createOperations(): improve results of compoundCRS to compoundCRS case (#2131)
 o hgridshift/vgridshift: defer grid opening when grid has already
   been opened (#2132)
 o Resolve a few shadowed declaration warnings (#2142)
 o ProjectedCRS identification: deal with switched 1st/2nd std parallels for
   LCC_2SP(#2153)
 o Fix Robinson inverse projection (#2154)
 o createOperations(): do not remove ballpark transformation if there are only
   grid based operations, even if they cover the whole area of use (#2156)
 o createFromCoordinateReferenceSystemCodes(): 'optimization' to avoid using
   C++ exceptions (#2161)
 o Ingestion of WKT1_GDAL: correctly map 'Cylindrical_Equal_Area' (#2167)
 o Add limited support for non-conformant WKT1 LAS COMPD_CS[] (#2172)
 o PROJ4 string import: take into correctly non-metre unit when the string
   looks like the one for WGS 84 / Pseudo Mercator (#2177)
 o io.hpp: avoid dependency to proj_json_streaming_writer.hpp (#2184)
 o Fix support of WKT1_GDAL with netCDF rotated pole formulation (#2186)
6.3.2 Release Notes
 Bug fixes
 o validateParameters(): fix false-positive warning on
   Equidistant Cylindrical (#1947)
 o proj_create_crs_to_crs(): avoid potential reprojection failures when
   reprojecting area of use to source and target CRS (#1993)
   and +pm= (#2003)
 o Fix bad copy&replace pattern on HEALPix and rHEALPix projection names (#2006)
   factor (#2013)
 o data/Makefile.am: remove bashism (#2047)
 o ProjectedCRS::identify(): tune it to better work with ESRI WKT representation
   of EPSG:2193 (#2058)
 o EngineeringCRS: when exporting to WKT1_GDAL, output unit and axis (#2091)
 o Add missing entries in grid_alternatives for Portugal grids coming from
   ESRI entries (#2103)
 o Fix working of Helmert transform between the horizontal part of 2
   compoundCRS (#2110)
   possible (#2118)
   geographic CRS as 3D (#2124)
 o createOperations(): improve results of compoundCRS to compoundCRS case (#2130)
 o PROJ4 string import: take into correctly non-metre unit when the string looks
   like the one for WGS 84 / Pseudo Mercator (#2178)
 o Fix support of WKT1_GDAL with netCDF rotated pole formulation (#2187)
 o io.hpp: avoid dependency to proj_json_streaming_writer.hpp (#2188)
PROJ mailing list
PROJ at lists.osgeo.org<mailto:PROJ at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/proj
PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200501/5a6de813/attachment.html>
More information about the PROJ mailing list
