[PROJ] Matching EPSG:3005
Nyall Dawson nyall.dawson at gmail.com
Wed May 6 15:04:25 PDT 2020
On Thu, 7 May 2020 at 07:10, Even Rouault <even.rouault at spatialys.com> wrote:
> On jeudi 7 mai 2020 06:23:37 CEST Nyall Dawson wrote:
> > On Thu, 7 May 2020 at 05:46, Even Rouault <even.rouault at spatialys.com> wrote:
> > > Do not hesitate to give the full context for your question. I suspect this
> > > is related to https://github.com/qgis/QGIS/issues/36216 and Oracle WKT.
> > Correct! I'm mid way through a reply to that (but I'm blaming Oracle
> > here, not proj!)
> Would I be mean if I'd point that they opted for not being part of the team supporting the GDAL barn effort :-) ?
Thanks for the explanations!
Given the above, I've closed off the issue with this resolution:
"So the fix here would be:
Speak to your oracle rep and request that they fix the incorrect
authority definition in mdsys.cs_srs
Pressure your oracle sales rep to get Oracle to fund improvements in
the proj library to handle Oracle's "special" variants of WKT"
(Because I'm with you, and have 0 motivation to spend any effort
supporting such a fundamentally shitty database)
Nyall
More information about the PROJ mailing list
