[PROJ] Deformation model implementation
Even Rouault even.rouault at spatialys.com
Mon May 11 02:02:33 PDT 2020
Over the course of past years, we discussed here or in
https://github.com/OSGeo/PROJ/issues/1001 how to extend PROJ to deal with deformation
models able to cope with 3D time-dependent deformations, and particularly, multiple ources
of deformations with different time constants, such as secular velocity models for GIA
(glacial isostatic adjustment), or complex deformations due tectonic events such as
earthquakes, which may include both coseismic deformation (a step function) as well an
ongoing post-seismic deformation signal.
Chris Crook wrote a specification of an encoding for such a deformation model [1], consisting
of a main JSON file describing general metadata and parameters of the model, and listing
different spatial components with their associated time function (velocity, step/reverse step,
constant, exponential, piece-wise). The grids of each spatial component use the Geodetic
TIFF grids (GTG) profile of GeoTIFF ([2]) that is available since PROJ 7.0.
The PROJ implementation for this deformation model specification is now available for
review in the pull request
https://github.com/OSGeo/PROJ/pull/2206 . Chris has tested it on the NZGD200 deformation
model.
Even
[1]
https://github.com/linz/deformation-model-format/blob/master/doc/
JsonGeotiffDeformationModelFormat_20200501.pdf
[2] https://proj.org/specifications/geodetictiffgrids.html
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200511/0214d781/attachment.html>
More information about the PROJ mailing list
