[PROJ] build the earth custom projection
strebe at aol.com strebe at aol.com
Tue May 19 23:44:02 PDT 2020
 Are you asking if it would be possible to add a projection of known construction into PROJ? Or are you asking if the projection details are known to sufficient detail to add it into PROJ? Or are you asking if someone is willing to do this? Or…?
— daan
-----Original Message-----
To: proj at lists.osgeo.org
Sent: Tue, May 19, 2020 9:37 pm
Subject: [PROJ] build the earth custom projection
Hi everyone. A while back, the build the earth project changed their projection to a custom made one. It is a conformal dymaxion bisected along the north pole and deals with more complex math. I was researching custom projections for qgis and was wondering if it was even possible to recreate the projection. Thanks for all your help.
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200520/13a9e81e/attachment.html>
More information about the PROJ mailing list
