[PROJ] About unit conversion
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Wed May 20 10:24:07 PDT 2020
I just had a quick look, but to me it looks like you are trying to convert between angles and distances?
+proj=utm gives angular results that can be converted to deg, rad or maybe gon, but NOT to m, km of ft! This is such a fundamental part of how PROJ works, that it is probably not explained in the documentation.
If I mis understood, sorry for the confusion.
Kind regards, Jochem
-----Original Message-----
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of José Luis García Pallero
Sent: woensdag 20 mei 2020 18:34
To: Kristian Evers <kreve at sdfe.dk>
Cc: proj at lists.osgeo.org
Subject: Re: [PROJ] About unit conversion
El mié., 20 may. 2020 a las 11:00, Kristian Evers (<kreve at sdfe.dk>) escribió:
> I see that you don't specify the input units in your unitconvert
> steps. Try adding a
> +xy_in parameter to your unitconvert steps and see if that fixes the problem.
> When you only specify of of either +xy_in or +xy_out the operation
> becomes somewhat uni-directional which is why not all of your pipelines works in reverse.
> See https://proj.org/operations/conversions/unitconvert.html for more.
Thank you for your answer, Kristian, but I can't understand why my program fails. Clearly, for FWD and input in radians and output in meters all works without any unitconversion. Also for INV step with meters as input and radians as output, i.e., using only "+proj=utm
+lon_0=3w +ellps=GRS80" as parameters string is enough. Also for any
combination in the FWD step all works.
For example using "+proj=pipeline +step +proj=unitconvert +xy_in=deg
+step +proj=utm +lon_0=3w +ellps=GRS80 +step +proj=unitconvert
+xy_out=km" accepts as input degrees and returns kilometers. But I
cant understand why in this case for the INV step the parameters string "+proj=pipeline +step +proj=unitconvert +xy_in=km +step
+proj=utm +lon_0=3w +ellps=GRS80 +step +proj=unitconvert +xy_out=deg"
is incorrect. I've tested several combinations and none of them works:
"+proj=utm +lon_0=3w +ellps=GRS80" -> wrong results "+proj=pipeline +step +proj=unitconvert +xy_in=km +step +proj=utm
"+proj=pipeline +step +proj=unitconvert +xy_in=km +xy_out=m +step
+proj=utm +lon_0=3w +ellps=GRS80" -> wrong results (same numeric value
as before)
"+proj=pipeline +step +proj=unitconvert +xy_in=km +xy_out=deg +step
+proj=utm +lon_0=3w +ellps=GRS80" -> proj_create: Error -59
(inconsistent unit type between input and output): Pipeline: Bad step
definition: proj=unitconvert (inconsistent unit type between input and
output)
"+proj=pipeline +step +proj=utm +lon_0=3w +ellps=GRS80 +step
+proj=unitconvert +xy_in=km +xy_out=deg" -> proj_create: Error -59
output)
"+proj=pipeline +step +proj=unitconvert +xy_out=deg +step +proj=utm
+lon_0=3w +ellps=GRS80 +step +proj=unitconvert +xy_in=km" -> wrong
results
+lon_0=3w +ellps=GRS80 +step +proj=unitconvert +xy_out=deg" -> wrong
results
I can't understand the way as unitconvert works, neither reading https://proj.org/operations/conversions/unitconvert.html
For only one conversion (km to radians or meters to degrees) the problem is only again with the INV step
Thanks
> /Kristian
> > García Pallero
> > Sent: 19. maj 2020 10:59
> > To: proj at lists.osgeo.org
> > I've written a small program in order to illustrate my last mail.
> > Attached (and pasted at the bottom of the message) I send the code.
> > The results are
> > Original data -> lon: -6.00000, lat: 43.00000 (degrees) -> lon:
> > -0.1047197551, lat: 0.7504915784 (radians)
> > rad to m  -> X= 255466.981, Y=4765182.933 (+proj=utm +lon_0=3w
> > +ellps=GRS80)
> > rad to km -> X=    255.467, Y=   4765.183 (+proj=pipeline +step
> > +proj=utm +lon_0=3w +ellps=GRS80 +step +proj=unitconvert +xy_out=km)
> > deg to m  -> X= 255466.981, Y=4765182.933 (+proj=pipeline +step
> > +proj=unitconvert +xy_in=deg +step +proj=utm +lon_0=3w +ellps=GRS80)
> > deg to km -> X=    255.467, Y=   4765.183 (+proj=pipeline +step
> > m  to rad -> lon=-0.1047197551, lat= 0.7504915784 (+proj=utm
> > +lon_0=3w
> > +ellps=GRS80)
> > km to rad -> lon=-0.0001306633, lat= 0.0000007501 (+proj=pipeline
> > +step +proj=unitconvert +xy_in=km +step +proj=utm +lon_0=3w
> > +ellps=GRS80)
> > m  to deg -> lon=-0.1300126568, lat= 0.0130928532 (+proj=pipeline
> > +xy_out=deg)
> > km to deg -> lon=-0.0001307025, lat= 0.0000000131 (+proj=pipeline
> > +ellps=GRS80 +step +proj=unitconvert +xy_out=deg)
> > As you can see, the only right INV conversion is the
> > meters_to_radians one. All other combinations produce all different
> > results, but all combinations for the FWD step are right. Im using
> > PROJ 7.0.1 from the Debian Sid repositories
> > #include<stdio.h>
> > #include<stdlib.h>
> > #include<math.h>
> > #include<proj.h>
> > #define CONST_PI (3.14159265358979323846264338328) int main() {
> >     double lond1=-6.0,latd1=43.0,lond2=lond1,latd2=latd1;
> >     double
> > lonr1=lond1*CONST_PI/180.0,latr1=latd1*CONST_PI/180.0,lonr2=lonr1,la
> > tr2
> > =latr1;
> >     char param_rad_to_m[]="+proj=utm +lon_0=3w +ellps=GRS80";
> >     char param_rad_to_km[]="+proj=pipeline +step +proj=utm +lon_0=3w
> > +ellps=GRS80 +step +proj=unitconvert +xy_out=km";
> >     char param_deg_to_m[]="+proj=pipeline +step +proj=unitconvert
> > +xy_in=deg +step +proj=utm +lon_0=3w +ellps=GRS80";
> >     char param_deg_to_km[]="+proj=pipeline +step +proj=unitconvert
> > +xy_in=deg +step +proj=utm +lon_0=3w +ellps=GRS80 +step
> >     char param_m_to_rad[]="+proj=utm +lon_0=3w +ellps=GRS80";
> >     char param_km_to_rad[]="+proj=pipeline +step +proj=unitconvert
> > +xy_in=km +step +proj=utm +lon_0=3w +ellps=GRS80";
> >     char param_m_to_deg[]="+proj=pipeline +step +proj=utm +lon_0=3w
> > +ellps=GRS80 +step +proj=unitconvert +xy_out=deg";
> >     char param_km_to_deg[]="+proj=pipeline +step +proj=unitconvert
> > +xy_in=km +step +proj=utm +lon_0=3w +ellps=GRS80 +step
> >     PJ_CONTEXT *C=proj_context_create();
> >     PJ *proj=NULL;
> >     size_t ld=sizeof(double);
> >     //Display original data
> >     printf("Original data -> lon: %.5lf, lat: %.5lf (degrees) -> lon:
> > %.10lf, lat: %.10lf (radians)\n\n",
> >            lond1,latd1,lonr1,latr1);
> >     //FWD, radiands to meters
> >     proj = proj_create(C,param_rad_to_m);
> > proj_trans_generic(proj,PJ_FWD,&lonr1,ld,1,&latr1,ld,1,NULL,0,0,NULL,0,0);
> >     printf("rad to m  -> X=%11.3lf, Y=%11.3lf
> > (%s)\n",lonr1,latr1,param_rad_to_m);
> >     proj_destroy(proj);
> >     //FWD, radiands to kilometers
> >     proj = proj_create(C,param_rad_to_km);
> > proj_trans_generic(proj,PJ_FWD,&lonr2,ld,1,&latr2,ld,1,NULL,0,0,NULL,0,0);
> >     printf("rad to km -> X=%11.3lf, Y=%11.3lf
> > (%s)\n",lonr2,latr2,param_rad_to_km);
> >     proj_destroy(proj);
> >     //FWD, degrees to meters
> >     proj = proj_create(C,param_deg_to_m);
> > proj_trans_generic(proj,PJ_FWD,&lond1,ld,1,&latd1,ld,1,NULL,0,0,NULL,0,0);
> >     printf("deg to m  -> X=%11.3lf, Y=%11.3lf
> > (%s)\n",lond1,latd1,param_deg_to_m);
> >     proj_destroy(proj);
> >     //FWD, degrees to kilometers
> >     proj = proj_create(C,param_deg_to_km);
> > proj_trans_generic(proj,PJ_FWD,&lond2,ld,1,&latd2,ld,1,NULL,0,0,NULL,0,0);
> >     printf("deg to km -> X=%11.3lf, Y=%11.3lf
> > (%s)\n\n",lond2,latd2,param_deg_to_km);
> >     proj_destroy(proj);
> >     //INV, meters to radians
> >     proj = proj_create(C,param_m_to_rad);
> >     proj_trans_generic(proj,PJ_INV,&lonr1,ld,1,&latr1,ld,1,NULL,0,0,NULL,0,0);
> >     printf("m  to rad -> lon=%13.10lf, lat=%13.10lf
> > (%s)\n",lonr1,latr1,param_m_to_rad);
> >     proj_destroy(proj);
> >     //INV, kilometers to radians
> >     proj = proj_create(C,param_km_to_rad);
> >     proj_trans_generic(proj,PJ_INV,&lonr2,ld,1,&latr2,ld,1,NULL,0,0,NULL,0,0);
> >     printf("km to rad -> lon=%13.10lf, lat=%13.10lf
> > (%s)\n",lonr2,latr2,param_km_to_rad);
> >     proj_destroy(proj);
> >     //INV, meters to degrees
> >     proj = proj_create(C,param_m_to_deg);
> > proj_trans_generic(proj,PJ_INV,&lond1,ld,1,&latd1,ld,1,NULL,0,0,NULL,0,0);
> >     printf("m  to deg -> lon=%13.10lf, lat=%13.10lf
> > (%s)\n",lond1,latd1,param_m_to_deg);
> >     proj_destroy(proj);
> >     //INV, kilometers to degrees
> >     proj = proj_create(C,param_km_to_deg);
> > proj_trans_generic(proj,PJ_INV,&lond2,ld,1,&latd2,ld,1,NULL,0,0,NULL,0,0);
> >     printf("km to deg -> lon=%13.10lf, lat=%13.10lf
> > (%s)\n",lond2,latd2,param_km_to_deg);
> >     proj_destroy(proj);
> >     proj_context_destroy(C);
> >     return 0;
> > El lun., 18 may. 2020 a las 23:03, José Luis García Pallero
> > (<jgpallero at gmail.com>) escribió:
> > > Hello:
> > > I'm trying to do dome projections (forward and inverse) using the
> > > function proj_trans_generic() and parameter string in PROJ format
> > > style) and I'm a bit confused about unit conversions. My reference
> > > for the syntax is
> > > For the forward problem I write
> > > C = proj_context_create();
> > > projection = proj_create(C,param);
> > proj_trans_generic(projection,PJ_FWD,lon,sizeof(double),nElem,lat,si
> > zeof(d
> > ouble),nElem,NULL,0,0,NULL,0,0);
> > > I've used the param string
> > > '+proj=pipeline +step +proj=unitconvert +xy_in=deg +step +proj=utm
> > > +lon_0=3w +ellps=GRS80 +step +proj=unitconvert +xy_out=km'
> > > which means that the input coordinates are in degrees and the
> > > output in kilometers. All works right. The results are the same if
> > > I pass the input coordinates in radians and I use the param string
> > > '+proj=pipeline +step +proj=utm +lon_0=3w +ellps=GRS80 +step
> > > The problem comes when I try to do the inverse step. The procedure
> > > is the
> > same:
> > proj_trans_generic(projection,PJ_INV,x,sizeof(double),nElem,y,sizeof
> > (doubl
> > > In the input xoordinates are in meters and I use the param string
> > > '+proj=utm +lon_0=3w +ellps=GRS80'
> > > The resulting longtude and latitude are correct and the units are
> > > radians. But if I use the param string
> > > +proj=unitconvert +xy_out=deg'
> > > The output is totally wrong. I expect degrees, but the values have
> > > no sense. Also, if I use the input X and Y in kilometers ans the
> > > param string is
> > > '+proj=pipeline +step +proj=unitconvert +xy_in=km +step +proj=utm
> > > the result is wrong again.
> > > I suppose I'm doing something wrong with unit conversion, but I
> > > can not
> > find it
> > > Can someone help me?
> > > Thanks
> > > (o<
> > > V_/_
> > > Use Debian GNU/Linux and enjoy!
> > (o<
> > V_/_
(o<
V_/_
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
