[PROJ] Can't obtain meridian convergence and scale factor
Jose Gonçalves jagoncal at gmail.com
Thu Nov 5 09:56:48 PST 2020
Your input is projected coordinates. You should do the inverse:
echo 600000 2200000 | proj -I +init=IGNF:LAMBE -SV
Regards
José Gonçalves
Em qui., 5 de nov. de 2020 às 15:08, Nicolas Bellaiche
<Nicolas.Bellaiche at ign.fr> escreveu:
> Hi,
> I'm struggling computing the scale factor and the meridian convergence from a PJ object. I'm working with the C++ API, but even with the executable proj, it doesn't seem to work properly:
> echo 600000 2200000 | proj +init=IGNF:LAMBE -SV
> sends back
> #Lambert Conformal Conic
> # Conic, Sph&Ell
> # lat_1= and lat_2= or lat_0, k_0=
> # +init=IGNF:LAMBE +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=0 +k_0=0.99987742
> # +x_0=600000 +y_0=2200000 +ellps=clrk80ign +pm=paris +units=m +no_defs
> #--- following specified but NOT used
> # +type=crs
> #Final Earth figure: ellipsoid
> #  Major axis (a): 6378249.200
> #  1/flattening: 293.466021
> #  squared eccentricity: 0.006803487646
> Rel. 7.0.0, March 1st, 2020
> <proj>: while processing file: <stdin>, line 1
> latitude or longitude exceeded limits
> What's wrong? Bug in the code or misunderstanding from me.
> Thanks a lot,
> Nicolas Bellaiche
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
