[PROJ] How to transform XYZ to NEU
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Fri Nov 20 21:51:06 PST 2020
Hi Lei,
Although some users have asked for this feature before, there is no specific PROJ functionality for this. However, you can do the transformation with cct if you use the right parameters:
https://github.com/OSGeo/PROJ/issues/500
Regards, Jochem
From: PROJ <proj-bounces at lists.osgeo.org> on behalf of leiyang at fio.org.cn <leiyang at fio.org.cn>
Sent: Saturday, 21 November 2020, 02:13
To: proj
Subject: [PROJ] How to transform XYZ to NEU
I have the  coordinates of XYZ under earth geocentirc system. I would like to transform them to the NEU (North East Up) system which is a GNSS frequently used system.
Now I know the cct could do the transform XYZ to BLH:
echo 4097216.6805  4429119.0287 -2065771.3676 0 | cct -I +proj=cart +ellps=GRS80
47.2292116930  -19.0183060232     1552.9924        0.0000
But I do not know how to transform it to NEU. I also checked the documents, and find no answer.
Thanks
Lei
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20201121/44d320b3/attachment.html>
More information about the PROJ mailing list
