[PROJ] Geoidmodel in WKT without grid file
Even Rouault even.rouault at spatialys.com
Tue Nov 24 07:43:18 PST 2020
Javier,
The code paths that deal with the GEOIDMODEL[] and finding a transformation
from/into a VerticalCRS aren't exactly the same. In the code path of the
GEOIDMODEL[], no ballpark vertical transformation was added, so when the grid
is missing, no transformation can be done.
I've addressed this per https://github.com/OSGeo/PROJ/pull/2449 by making sure
a ballpart vertical transformation is also added
Even
http://www.spatialys.com
More information about the PROJ mailing list
