[PROJ] EPSG v10 update status
Even Rouault even.rouault at spatialys.com
Thu Oct 8 17:13:40 PDT 2020
I've now code ready to handle the update to EPSG v10
(https://github.com/OSGeo/PROJ/issues/2355). There are some backward compatibility
challenges & risk assessment to do. See the cover text of https://github.com/OSGeo/PROJ/
pull/2370 (targetted for 7.2) and
https://github.com/OSGeo/PROJ/pull/2371 (targetted for 8.0) for details.
It would be appreciated if downstream PROJ users could give a try at least at #2370 to
confirm it doesn't break in major ways their apps.
And possibly also try #2371, but if your code inspects the details of objects, like accessing
the datum of a CRS, be prepared for the dreaded datum ensemble concept to show up (for
anything based on WGS84 and ETRS89), in which case you may need to use new functions
added in the C API.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20201009/4522de2d/attachment.html>
More information about the PROJ mailing list
