[PROJ] EPSG v10 update status
Roger Bivand Roger.Bivand at nhh.no
Fri Oct 9 08:25:13 PDT 2020
On Fri, 9 Oct 2020, Even Rouault wrote:
> Roger,
>> Is there a specific PR/fork of GDAL that matches rouault/PROJ:epsg10?
>> Testing for the R packages I'm involved with uses both, so GDAL would need
>> to use PROJ functions adapted for v10.
> To test just rouault/PROJ:epsg10, you don't need any special GDAL
> patched version as the objects returned by PROJ will still have the same
> structure as before (no datum ensemble)
Thanks! I've tested sf and rgdal, and apart from changing column numbers
in the DB table for 10 compared to 9, things seem OK. I'll look to run
tests on R packages using sf or rgdal later. The only changes were in
documentation, where I opened proj.db directly from RSQLite to display the
contents, so not to do with PROJ or PR #2370.
I'll move to check part2 once 7.2 is published.
Best wishes,
Roger
> To test rouault/PROJ:epsg10_part2 with GDAL, you need
> https://github.com/OSGeo/gdal/pull/3033 that contains fixes for dealing with datum
> ensemble.
> Even
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
More information about the PROJ mailing list
