[PROJ] PROJ 7.2.0RC1 and PROJ-data 1.3RC1
Kristian Evers kristianevers at gmail.com
Mon Oct 26 05:34:12 PDT 2020
That’s weird, I’ve set them exactly the same in both CMake and autotools:
https://github.com/OSGeo/PROJ/commit/3bd548d816f141b617c7b3252e22b4f0b7fdd352 <https://github.com/OSGeo/PROJ/commit/3bd548d816f141b617c7b3252e22b4f0b7fdd352>
Is this perhaps because PROJ_API_VERSION in CmakeLists.txt should be set to
current-age instead of just current?
/Kristian
> On 26 Oct 2020, at 13:28, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
> The library SOVERSION is out of sync between the CMake and Autotools
> buildsystems.
> CMake uses 21 and Autotools uses 19.
> The version-info for autotools should probably be: 21:0:0
> The current value, 21:0:2, results in 19 (21 - 2).
> Kind Regards,
> Bas
> GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20201026/c8126469/attachment.html>
More information about the PROJ mailing list
