[PROJ] PROJ 7.2.0RC1 and PROJ-data 1.3RC1
Kristian Evers kristianevers at gmail.com
Mon Oct 26 06:05:24 PDT 2020
> On 26 Oct 2020, at 13:55, Even Rouault <even.rouault at spatialys.com> wrote:
> On lundi 26 octobre 2020 13:34:12 CET Kristian Evers wrote:
>> That’s weird, I’ve set them exactly the same in both CMake and autotools:
>> https://github.com/OSGeo/PROJ/commit/3bd548d816f141b617c7b3252e22b4f0b7fdd35
>> 2
>> <https://github.com/OSGeo/PROJ/commit/3bd548d816f141b617c7b3252e22b4f0b7fdd
>> 352>
>> Is this perhaps because PROJ_API_VERSION in CmakeLists.txt should be set to
>> current-age instead of just current?
> Yes
I’ll update HOWTORELEASE to reflect this then.
> and PROJ_BUILD_VERSION should not be set to current:revision:age, but to X.Y.Z
> which only non-mortals can guess from current:revision:age. The pragramatic
> way of having X.Y.Z right is to do a autoconf build and look at the generated
> libproj.so.X.Y.Z . But this would only work on the operating system from which
> you did the build, since the libtool current:revision:age versionning scheme
> translates to different X.Y.Z versions given the operating system... So it
> seems there's no way to make sure that a cmake build will result in the same
> .so.* files as a autoconf+libtool build
I’ll leave this be until there’s a way to set this properly for mortals. I can update
the numbers based on my MacOS builds but that will just cause different issues
i believe.
/Kristian
More information about the PROJ mailing list
