[PROJ] Ellipsoidal height VCRS in WKT/EPSG
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Sep 1 03:46:33 PDT 2020
Hi
Does exist any EPSG or WKT for a Vertical CRS that means "ellipsoidal
height"?
To define a 3D CRS I just make a compound CRS with a horizontal and a
vertical one.
I could just remove any VCRS for ellipsoidal heights. However I cannot make
the difference if the user actively selected "ellipsoidal height" for VCRS,
or just forgot (or don't know) it.
I don't want to "promoteTo3D" the 2D CRS  adding the third axis, because it
removes the authority.
Thanks.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200901/23e2d37e/attachment.html>
More information about the PROJ mailing list
