[PROJ] "Local" projection method?
Even Rouault even.rouault at spatialys.com
Thu Sep 24 02:01:22 PDT 2020
On jeudi 24 septembre 2020 05:42:22 CEST Kristian Evers wrote:
> Nyall,
> > Based on this, would it be appropriate to directly map this projection
> > method across to the "Orthographic" method? Or am I missing something
> > important?…
> Yes, it would seem so. Be aware though, the current Orthographic projection
> implementation in PROJ is only valid in the spherical case. You would have
> to extend that to the ellipsoidal case for the mapping described by Esri.
> We’ve got an old issue [0] which contains some hints on how to go about
> that.
"Recent" EPSG guidance note 7.2
https://drive.tiny.cloud/1/4m326iu12oa8re9cjiadxonharclteqb4mumfxj71zsttwkx/
62018e48-9da4-43e7-b598-1202cd96ec9f
(link got from epsg.org)
has the maths for the ellipsoidal formulation of the orthographic projection in paragraph
3.3.5, page 89
I cannot comment on the full equivalence of the "Local" projection, but hopefully in the
Scale_Factor=1 + Azimuth=0 case, they would match.
One way to check that the theory local = ortho on the sphere is valid would be to use ArcGIS
with a sphere as the ellipsoid and compare results with +proj=ortho
Other point:
Looking at
https://pro.arcgis.com/en/pro-app/help/mapping/properties/orthographic.htm ,
there's the Auxiliary Sphere Type parameter that can be used to change how orthographic is
computed on an ellipsoid, but I'm not sure any of the listed method is equivalent to the
ellipsoidal formulation from EPSG, as the ellipsoidal formulation from EPSG doesn't seem to
use authalic latitude.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200924/79f34b3e/attachment.html>
More information about the PROJ mailing list
