[PROJ] Changes in area of use bounds for EPSG 3035 between major versions
Stephan Hügel urschrei at gmail.com
Wed Aug 18 10:53:50 PDT 2021
Thanks both!
s
> On 18 Aug 2021, at 18:50, Javier Jimenez Shaw <j1 at jimenezshaw.com> wrote:
> It seems a change in EPSG.
> This is the CRS: https://epsg.org/crs_3035/ETRS89-extended-LAEA-Europe.html
> This is the Extent: https://epsg.org/extent_2881/Europe-LCC-LAEA.html
> that was modified in January 2021: https://epsg.org/closed-change-request/browse/id/2020.127
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Wed, 18 Aug 2021 at 19:34, Stephan Hügel <urschrei at gmail.com> wrote:
> We’ve recently updated the PROJ version in use by rust-proj from 7.2.1 to 8.1.0, which caused a test failure:
> One of our tests interrogates the area of use for EPSG:3035 using get_area_of_use. In 7.2.1, that was:
> west, -35.58
> south, 24.6
> east, 44.83
> north, 84.17
> But north has changed to 84.73 in v8.1.0
> I’m not claiming this is wrong, but it’s a large change so I thought I’d ask if anyone can shed some light on it…
> s
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
