[PROJ] PROJ 8.1.1RC1
Even Rouault even.rouault at spatialys.com
Thu Aug 26 05:37:27 PDT 2021
Kristian,
there's a discrepancy in .so.x.y.z numbers on Linux depending if you use
autoconf or cmake
$ ll ~/proj/install-proj-8.1.1-ac/lib/*.so*
libproj.so -> libproj.so.22.1.1*
libproj.so.22 -> libproj.so.22.1.1*
libproj.so.22.1.1*
$ ll ~/proj/install-proj-8.1.1-cmake/lib/*.so*
libproj.so.22 -> libproj.so.23.1.1
libproj.so.23.1.1
CMakeLists.txt should probably be changed to have
set(PROJ_BUILD_VERSION "22.1.1")
The libtool version info current:revision:age (23:1:1) doesn't result in
.so.current.revision.age but something with a bit more maths that only
double PhD owners can figure out (apologies if you're one of those :-) :-))
Even
Le 26/08/2021 à 05:54, Kristian Evers a écrit :
> All,
> I have prepared a release candidate for the upcoming version 8.1.1 of PROJ.
> Archives are available here
> http://download.osgeo.org/proj/proj-8.1.1RC1.tar.gz
> http://download.osgeo.org/proj/proj-8.1.1RC1.zip
> The PROJ release includes a number of bug fixes and updates to the
> transformation database (see details below).
> Please test the release candidates and report your findings back
> to the mailing list.
> /Kristian
> 8.1.1 Release Notes
>   Updates
>   o EPSG Database updated to version 10.028 (#2773)
>   Bug Fixes
>   o Include algorithm header file to avoid build errors on Alpine Linux (#2769)
>   o CMake: fix installation of executables on iOS (#2766)
>   o Associate extents to transformations of CRS's that include GEOIDMODEL (#2769)
>   o Logging: avoid some overhead when logging is not enabled (#2775)
>   o ortho: remove useless and invalid log trace (#2777)
>   o CMake: remove external nlohmann_json from INTERFACE_LINK_LIBRARIES target (#2781)
>   o reateOperations(): fix SourceTargetCRSExtentUse::NONE mode (#2783)
>   o GeoTIFF grid reading: perf improvements (#2788)
>   o Conversion::createUTM(): avoid integer overflow (#2796)
>   o Inverse laea ellipsoidal: return PROJ_ERR_COORD_TRANSFM_OUTSIDE_PROJECTION_DOMAIN
>     when appropriates (#2801)
>   o Make sure that proj_crs_promote_to_3D returns a derived CRS (#2806)
>   o createOperations(): fix missing deg<-->rad conversion when transforming with a
>     CRS that has a fallback-to-PROJ4-string behaviour and is a BoundCRS of a
>     GeographicCRS (#2808)
>   o WKT2 import/export: preserve PROJ.4 CRS extension string in REMARKS[] (#2812)
>   o BoundCRS: accept importing/exporting in WKT2 and PROJJSON the
>     scope/area/extent/id attributes (#2815)
>   o ConcatenatedOperation::fixStepsDirection(): fix bad chaining of steps when
>     inverse map projection is involved in non-final step (#2819)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
