[PROJ] Pseudo-mercator
Even Rouault even.rouault at spatialys.com
Wed Dec 1 13:15:03 PST 2021
Andrew,
Le 01/12/2021 à 21:51, Andrew Patterson a écrit :
> Even,
> That seems like a logical suggestion!
> This is the WKT for the map that's off by ~75km. That
> 'latitude_of_center' seems to be contributing at the very least, but
> as I said before, there appears to be more to it than that because
> without it there's still a ~0.18deg latitude shift.
> PROJCS["WGS_84_Pseudo_Mercator",GEOGCS["WGS
> 84",DATUM["wgs_1984",SPHEROID["WGS
> 1984",6378137,298.257223563],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]],PROJECTION["Mercator_1SP"],PARAMETER["false_easting",0],PARAMETER["false_northing",0],PARAMETER["latitude_of_center",6.64456744726493],PARAMETER["central_meridian",0],PARAMETER["scale_factor",1],UNIT["Meter",1,AUTHORITY["EPSG","9001"]]]
That one is a very odd beast. The
PARAMETER["latitude_of_center",6.64456744726493] is completely
inconsistant with the name "WGS_84_Pseudo_Mercator". I see GDAL 2.4
honoured this latitude of center, as gdalsrsinfo on it returns
+proj=merc +lon_0=0 +lat_ts=6.64456744726493 +x_0=0 +y_0=0 +ellps=WGS84
+towgs84=0,0,0,0,0,0,0 +units=m +no_defs.    Newer PROJ versions have a
heustistics that only look at the name WGS_84_Pseudo_Mercator and ignore
the projection parameters to decide to use the official EPSG:3857 "WGS
84 / Pseudo-Mercator" definition. One could argue it is a bug to ignore
the latitude_of_center parameter, but this definition is very confusing
to start with. It is hard to know what the intention of the user was:
use official EPSG:3857 "WGS 84 / Pseudo-Mercator", or use a modified
version of it...
> This is the WKT for the map that's off by ~26km:
> PROJCS["Popular_Visualisation_CRS_Mercator_deprecated",GEOGCS["GCS_Popular
> Visualisation
> CRS",DATUM["D_Popular_Visualisation_Datum",SPHEROID["Popular_Visualisation_Sphere",6378137,0]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Mercator"],PARAMETER["central_meridian",0],PARAMETER["false_easting",0],PARAMETER["false_northing",0],PARAMETER["standard_parallel_1",0],UNIT["Meter",1]]
> Looking at it more closely, I'm not sure it actually is a
> pseudo-mercator  map. I think I say 'populator visualisation' and
> assumed it was. But it _is_ off by ~26km after moving from 2.4/6/1 ->
> 3.3/8.1.1
As far as I can see, GDAL 2.4 can't transform that to a PROJ.4 string at
all (it doesn't understand the "Mercator" projection), so I'm not sure
why you get a result at all with it. With recent PROJ,
$ projinfo
'PROJCS["Popular_Visualisation_CRS_Mercator_deprecated",GEOGCS["GCS_Popular
Visualisation
CRS",DATUM["D_Popular_Visualisation_Datum",SPHEROID["Popular_Visualisation_Sphere",6378137,0]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Mercator"],PARAMETER["central_meridian",0],PARAMETER["false_easting",0],PARAMETER["false_northing",0],PARAMETER["standard_parallel_1",0],UNIT["Meter",1]]'
returns
PROJ.4 string:
+proj=merc +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +R=6378137 +units=m +no_defs
+type=crs
WKT2:2019 string:
PROJCRS["Popular_Visualisation_CRS_Mercator_deprecated",
     BASEGEOGCRS["GCS_Popular Visualisation CRS",
         DATUM["Popular Visualisation Datum",
             ELLIPSOID["Popular_Visualisation_Sphere",6378137,0,
                 LENGTHUNIT["metre",1]],
             ID["EPSG",6055]],
         PRIMEM["Greenwich",0,
             ANGLEUNIT["Degree",0.0174532925199433]]],
     CONVERSION["unnamed",
         METHOD["Mercator (variant B)",
             ID["EPSG",9805]],
         PARAMETER["Latitude of 1st standard parallel",0,
             ANGLEUNIT["Degree",0.0174532925199433],
             ID["EPSG",8823]],
         PARAMETER["Longitude of natural origin",0,
             ID["EPSG",8802]],
         PARAMETER["False easting",0,
             LENGTHUNIT["metre",1],
             ID["EPSG",8806]],
         PARAMETER["False northing",0,
             ID["EPSG",8807]]],
     CS[Cartesian,2],
         AXIS["(E)",east,
             ORDER[1],
             LENGTHUNIT["metre",1,
                 ID["EPSG",9001]]],
         AXIS["(N)",north,
             ORDER[2],
                 ID["EPSG",9001]]]]
Which is a reasonable enough interpretation of this WKT. It could have
potentially been better recognized as the deprecated EPSG:3785 (which
PROJ then interprets as EPSG;3857), but there's no heuristics for that
particular formulation, so it is recognized as classic Mercator on a
sphere.  In practice, it should give identical results to official
EPSG:3857 "WGS 84 / Pseudo-Mercator", except when a datum transformation
is involved. So if you transform between WGS 84 and this, you should get
correct results. But results off by 26 km are beyond an ignored datum
shift (differences should be off by a few hundred of meters max), so I'm
not sure why you observe this.
> This is the WKT for a map that saw no change between GDAL/PROJ versions:
> PROJCS["WGS 84 / Pseudo-Mercator",GEOGCS["WGS
> 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Mercator_1SP"],PARAMETER["central_meridian",0],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],EXTENSION["PROJ4","+proj=merc
> +a=6378137 +b=6378137 +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +k=1 +units=m
> +nadgrids=@null +wktext +no_defs"],AUTHORITY["EPSG","3857"]]
Yes that one is the canonical WKT1:GDAL formulation
Even
http://www.spatialys.com
More information about the PROJ mailing list
