[PROJ] CRS explorer
Javier Jimenez Shaw j1 at jimenezshaw.com
Sun Dec 5 02:18:53 PST 2021
On Sat, 4 Dec 2021 at 13:54, Lesparre, Jochem <Jochem.Lesparre at kadaster.nl>
wrote:
> Hi Javier,
Jochem, Thanks for you answer and suggestions.
Thanks for the nice improvements. I like the name filtering! It could be
> useful to be able to use this for other columns too, like the area of use
> and code.
I thought about that, but finally decided not doing it. When you search for
the code, you want a single result (you don't want to "filter"): Ctrl+F
does that much better ;) About the area of use, their names are really
confusing sometimes. And it may collide with the CRS name. Picking a point
in the map would be better IMO.
BTW, the filter field tries to work like many search engines: use
double-quotes (") for searches with spaces, and a dash (-) to implement a
"not" filter... and combine as many as you want. It is explained in the
info (i) link.
> I was wondering: Since you give the option to sort on a column, why do you
> present the CRS types (Projected, Geographic, Geocentric etc.) in separate
> tables? If you add a column for the CRS type in the table, then you could
> present everything in a single table and an user can still sort on CRS type
> if needed. The advantage would be that the user can also sort on other
> columns for all CRS types at once.
Yes, it was also in the backlog of ideas. I would give the option to
display one way or the other, but may take some time to implement (yes, I
like giving options to the user... and later they ask what does it do ;).
> What does the option Sticky map do?
"Sticks" the map to the top of the viewport when you scroll down due to a
large table. See next answer.
What function does the checkbox in the column Area of use have?
Displays a green rectangle in the map with the area(s) of use selected.
Just hovering with the mouse shows an orange rectangle. Now you understand
why you need the sticky map option.
> Regards, Jochem
Cheers,
Javier.
> *From:* PROJ <proj-bounces at lists.osgeo.org> on behalf of Javier Jimenez
> Shaw <j1 at jimenezshaw.com>
> *Sent:* Friday, 3 December 2021, 16:01
> *To:* proj
> *Subject:* Re: [PROJ] CRS explorer
> Hi all
> Sorry for the late update to PROJ 8.2.0. I have been implementing it with
> GitHub Actions. But now it is available.
> https://jjimenezshaw.github.io/crs-explorer/
> Some features were added, like filtering by name, column ordering, better
> performance...
> I was thinking on adding links to static pages with the WKT1 of each CRS.
> Do you think it is useful?
> Cheers,
> Javier
> PS: I found some new astronomical CRSs (IAU_2015) that are type "other" in
> proj.db. What is that?
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Thu, 14 Oct 2021 at 12:57, Thomas Knudsen <knudsen.thomas at gmail.com>
> wrote:
> Javier,
> Thanks for developing this - it seems to be extremely useful!
> /Thomas
> Den tor. 14. okt. 2021 kl. 12.03 skrev Javier Jimenez Shaw <
> j1 at jimenezshaw.com>:
> Hi
> I have developed a simple webpage to search coordinate reference systems
> based on PROJ data. It includes a map where you can click a location,
> filtering the systems that has this location in their area of use.
> There are a couple of ideas to add in the backlog. But I hope it is
> already useful.
> Cheers,
> Javier.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de
> geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden
> van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you are not the intended recipient, you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents of
> this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products and
> services
> [https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211205/fb14bd66/attachment.html>
More information about the PROJ mailing list
