[PROJ] Tie breakers used when ordering candidate operations
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Fri Feb 12 01:03:49 PST 2021
Greg wrote:
>  People talk about WGS84
Everyone should stop doing that and avoid EPSG:4326 at all times. ITRS is the one official international system, recognised by the UN.
Greg wrote:
> ITRF2008 is pretty much the same thing as WGS84(G1762) ), and ITRF2014
The major difference is that WGS84(G1762) is really messy at centimetre-level. It ignores the tracking station velocities during the year and uses an annual step-wise update (at a random date in January) of tracking station coordinates used to generate ephemeris broadcast message.
https://earth-info.nga.mil/GandG/publications/NGA_STND_0036_1_0_0_WGS84/NGA.STND.0036_1.0.0_WGS84.pdf
Greg wrote:
> So, I think people who ask for transforms to WGS84 should be told "That doesn't really make sense any more; I will assume you mean WGS84(G1762) which is basically the same as ITRF2014" and then you should use those transforms instead.
That is what I am doing all the time, except that I first ask them "Do you really want time-dependent international coordinates? Otherwise, I will assume you mean ETRF2000".
Regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message.
More information about the PROJ mailing list
