[PROJ] PROJ 8
Roger Bivand Roger.Bivand at nhh.no
Thu Feb 18 02:33:17 PST 2021
Thanks, Kristian!
On Thu, 18 Feb 2021, Kristian Evers wrote:
> Roger,
> The release is scheduled for March 1st and I will put out a release
> candidate within the next 2 or 3 days. As usual.
Good.
> The schedule for upcoming release can be found here
> https://github.com/OSGeo/PROJ/milestones. I will add the next years'
> worth of releases soon, but generally we do bi-monthly releases with
> alternating patch and minor version releases. Release candidates go out
> roughly a week before the release. We don't do alpha or beta versions.
> For that you will have to track changes in master. You probably already
> knew that.
Yes.
> The major change this time is the removal of proj_api.h. This has been
> announced well in advance so I don't think a larger time gap between RC
> and final release will make any difference if downstream projects
> haven't adapted yet.
Right, R packages are OK and condition on PROJ version (the Solaris test
platform is stuck at 5.2.0).
> I don't anticipate any major issues with the upcoming release but since
> this is a major version bump there is always a risk. I would expect any
> problems to be related to changes in the autotools/CMake setups, those
> are usually found quickly by the packagers and easily resolved. In case
> something larger surfaces we can postpone the final release until that
> is taken care of.
> On a related note, if someone out there should be eager to take on the
> role of release manager for PROJ I am happy to hand over that
> responsibility. It is definitely possible to run a tighter ship,
> unfortunately I just haven't got the available time for that.
I understand; other important components are in the same position. I
think, however, that the introuction of pipelines, the transition to an
SQL database, and the availability of the CDN have moved PROJ to a much
better position. Thanks very much for having really made a difference!
Roger
> Best,
> Kristian
>> -----Original Message-----
>> From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Roger Bivand
>> Sent: 18. februar 2021 10:00
>> To: PROJ <proj at lists.osgeo.org>
>> Subject: [PROJ] PROJ 8
>> Could I please ask for dates for alpha/beta/RC for PROJ 8? Should we
>> anticipate 1 March (in roughly 10 days) as before, or is there another
>> timmetable? 10 days is a bit tight for downstream to adapt code if
>> necessary. Is the current state of the main branch what should be expected
>> as alpha?
>> Roger
>> Roger Bivand
>> Department of Economics, Norwegian School of Economics,
>> Helleveien 30, N-5045 Bergen, Norway.
>> voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
>> https://orcid.org/0000-0003-2392-6140
>> https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
Roger Bivand
More information about the PROJ mailing list
