[PROJ] Any known issues with PROJ on Apple Silicon?
Corey Farwell coreyf at rwell.org
Wed Jan 20 10:43:34 PST 2021
Hey PROJ folks,
I'm working with a couple others debugging an issue with the Rust bindings
for PROJ. Specifically, the tests are failing on the latest MacBook Air,
which runs on Apple M1 which is ARM-based. I'm curious if anyone else in
the community has run into issues with PROJ running on ARM or Apple
Silicon. Thanks!
GitHub Issue: https://github.com/georust/proj/issues/52
Minimal code to reproduce the test failure:
https://github.com/georust/proj/blob/frewsxcv-min/src/main.rs
Corey Farwell
coreyf at rwell.org
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210120/027c9df1/attachment.html>
More information about the PROJ mailing list
