[PROJ] Is there Doxygen documentation?
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Jul 13 08:49:25 PDT 2021
Hi
I remember I mentioned some time ago that the sphinx formatting for C++ was
strange, missing spaces.
Looks like it was finally fixed:
https://github.com/readthedocs/sphinx_rtd_theme/issues/694#issuecomment-870351210
Just FYI.
Javier.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Wed, 21 Apr 2021 at 12:41, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> GDAL publishes Doxygen because it used to do it before we switched to
> Sphinx.
> PROJ Doxygen doc isn't pushed on proj.org, but you can consult it locally
> Run ./scripts/doxygen.sh
> and open generated files in docs/build/doxygen_html/index.html
> Even
> Le 21/04/2021 à 12:21, Javier Jimenez Shaw a écrit :
> Hi
> In GDAL you can use two different C++ documentations:
>  - Sphinx : https://gdal.org/api/index.html#id3
>  - Doxygen : https://gdal.org/doxygen/index.html
> However in PROJ I could only find it in Sphinx format
>  - https://proj.org/development/reference/cpp/index.html#
> Am I missing something? Is there doxygen style doc for PROJ somewhere?
> Thanks.
> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
> -- http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210713/bf1bb6d8/attachment.html>
More information about the PROJ mailing list
