[PROJ] About Mexican Geoid
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Jul 19 01:43:13 PDT 2021
Hi
Recently I found that Mexico has a geoid model, used with vcrs NAVD88:
GGM10 - Geoide gravimétrico mexicano 2010
http://en.www.inegi.org.mx/temas/geoide/#Downloads
The file is a text format, lat, long, undulation. It should be easy to
import.
The reference is ITRF2008 epoch 2010 (it sounds strange to me not using
NAD83x, but it is fine, right?... well, epoch 2010 instead of 2005 may be a
problem)
Unfortunately I didn't find any transformation in EPSG from ITRF2008 (epoch
2010) to NAVD88. We should do a PROJ one for the database (or ask them to
do in EPSG, but without much hope).
The main problem, as usual, is the "home made" license (for everything in
their webpage). It seems to be very open, but it is not a "standard" one:
http://en.www.inegi.org.mx/contenidos/inegi/doc/terminos_info_t.pdf
What should we do?
Maybe somebody already researched this geoid previously.
Cheers,
Javier.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210719/0a57c2f5/attachment.html>
More information about the PROJ mailing list
