[PROJ] Questions about declaring a CRS
Martin Desruisseaux martin.desruisseaux at geomatys.com
Mon Jun 28 09:38:58 PDT 2021
Hello Floris
If a choice is possible, I would encourage to use one of the approaches
recognized by international standards:
  * Authority codes with axis order and units as defined by authority
    (e.g. "EPSG:4326" is /latitude/, /longitude/; if the reverse order
    is wanted then "CRS:84" can be used instead).
  * Well Known Text version 2 (a.k.a. ISO 19162).
  * Possibly the JSON format cited by Even in the future.
PROJ 6 and later support all the above. I think they are preferable to
PROJ strings for at least 2 reasons:
  * They are portable, with WKT 2 possibly the safest bet for now since
    it is an existing OGC and ISO standard. While PROJ is the most
    popular, it is nevertheless not the only map projection engine
    available, with each engine having their advantage and inconvenient.
    Other map projection engines are more likely to understand a CRS
    defined by international standards than by PROJ-specific strings.
    Even if R uses only PROJ, a R script may want to fetch data from a
    distant server backed by a different map projection engine.
  * For educational reason: the PROJ string syntax evolved from a system
    initially designed for map projections only, not for the more
    general context of transformations between arbitrary pairs of CRS.
    If users educate themselves by learning from PROJ strings, there is
    a risk that they confuse CRS with operations, that they believe that
    "+towgs84" is good practice, etc.
Regards,
     Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210628/f3ffcfd2/attachment.html>
More information about the PROJ mailing list
