[PROJ] Am I supposed to get same results with libproj if passing proj4 +proj from/to crs ?
Even Rouault even.rouault at spatialys.com
Tue Nov 9 15:48:47 PST 2021
Sandro,
there is a NAD27 to WGS84 datum shift involved. So this might depend on
the transformations registered in the PROJ database of the version you
use and the grids available.
Result (-11708740.522541871, 3209723.515103944) is suboptimal as it is
the you get when no grids are used
Result (-11708734.486616733, 3209717.223316072) is the one using the
conus / us_noaa_conus.tif grid
Whether PROJ networking is enabled (PROJ_NETWORK=ON) can influence the
result (if it is set, then the conus grid will be used even if not
installed locally)
Even
Le 10/11/2021 à 00:02, Sandro Santilli a écrit :
> I'm trying to obtain the *same* transformations from different
> libproj versions (5.2.0 and 7.2.1) by passing the *same*
> proj4 strings to the transformation, but I'm instead getting
> different results.
> In order to more easily test this I'm a small python script
> using pyproj:
>    http://strk.kbt.io/tmp/transform_test.py
> The script projects coordinates 0,0 from EPSG:32040
> to EPSG:3857, using the proj4 string found in
> PostGIS 3.1.4 spatial_ref_sys for those SRIDs.
> On a machine (pyproj-3.2.1 using libproj-ce980207.so.22.1.1)
> I'm getting these coordinates in output:
> On another machine (pyproj-2.6.1 using libproj.so.19)
> I'm getting these coordinates:
> Can you think of a reason why I'd get different numbers ?
> Would it be a regression for the libproj-ce980207.so.22.1.1
> version to return different numbers ?
> Please keep me in Cc in case of replies as I don't think I'm
> receiving emails sent to this list.
> --strk;
>    Libre GIS consultant/developer
>    https://strk.kbt.io/services.html
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
