[PROJ] Adjusting priorities in proj.db: grid vs helmert transformations
Craig de Stigter craig.destigter at koordinates.com
Sun Nov 14 12:31:02 PST 2021
Hey folks
We're trying to adjust proj to use a specific transformation between two
CRSes *by default* (ie. we don't want our calling software to have to be
explicit about which to use, since there are several places we're calling
PROJ from and we'd like to make them automatically consistent)
Stock proj 8.1.1 gives us these transform choices:
> $ PROJ_NETWORK=ON projinfo -s EPSG:4283 -t EPSG:7844 --spatial-test
intersects --summary
> Candidate operations found: 5
> EPSG:8048, GDA94 to GDA2020 (1), 0.01 m, Australia including Lord Howe Island, Macquarie Island, Ashmore and Cartier Islands, Christmas Island, Cocos (Keeling) Islands, Norfolk Island. All onshore and offshore.
> DERIVED_FROM(EPSG):8446, GDA94 to GDA2020 (3), 0.05 m, Australia - Australian Capital Territory; New South Wales; Northern Territory; Queensland; South Australia; Tasmania; Western Australia; Victoria.
> DERIVED_FROM(EPSG):8447, GDA94 to GDA2020 (2), 0.05 m, Australia - Australian Capital Territory; New South Wales; Northern Territory; Queensland; South Australia; Tasmania; Western Australia; Victoria.
The one we want is DERIVED_FROM(EPSG):8447, GDA94 to GDA2020 (2), which is
third in the list, and thus not chosen by default.
Aiming to bump that to the top of the list, we modified our proj.db build
to add this SQL:
> -- When transforming from GDA94 to GDA2020,
> -- use the distortion+conformal grid in preference to the conformal-only
grid.
> UPDATE grid_transformation
> SET accuracy = 0.0099
> WHERE auth_name = 'EPSG' AND code = 8447;
We expected this to bump the transform to the top of the list. It did bump
up by one slot, above the other grid-based transform (EPSG:8446). However,
it's still below the helmert transformation (EPSG:8048):
offshore.
> DERIVED_FROM(EPSG):8447, GDA94 to GDA2020 (2), 0.0099 m, Australia -
I couldn't find anything documenting that PROJ prefers Helmert transforms
over grid-based ones - merely that it prefers operations with defined
accuracy, and then prefers transforms in order of accuracy. In which case I
would have expected it to choose EPSG:8447 over EPSG:8048 now that we've
hacked the accuracy number.
Interestingly, setting the accuracy of the Helmert transform to NULL *did*
fix this:
> DERIVED_FROM(EPSG):8447, GDA94 to GDA2020 (2), 0.0499 m, Australia -
> EPSG:8048, GDA94 to GDA2020 (1), unknown accuracy, Australia including
and offshore.
So my questions are:
1. Is setting the accuracy of EPSG:8048 to NULL a bad idea? We'll still
want to use EPSG:8048 as an offshore fallback.
2. Any idea why PROJ is still prioritising EPSG:8048 after our first tweak?
3. Is there a better way to accomplish this reprioritisation?
Thanks a bunch!
Regards,
Craig
Platform Engineer
Koordinates
+64 21 256 9488 / koordinates.com / @koordinates
More information about the PROJ mailing list
