[PROJ] Adjusting priorities in proj.db: grid vs helmert transformations
Craig de Stigter craig.destigter at koordinates.com
Mon Nov 15 12:07:16 PST 2021
> When you know which transformation you want, you probably shouldn't use PROJ's search logic to find it
We're aware of that, though the project we're implementing involves
several separate subsystems and we don't control all the layers, so
we're unable to just call specific proj functions. So we're after a
way to get PROJ to use the transformation we want by default.
> I believe you run here in point 8 "consider as more relevant an operation whose area of use is larger" that comes before point 9 "consider as more relevant an operation that has a better accuracy.".
aha, this makes sense! I'm not sure why I missed this when reading those docs.
I can confirm that cs2cs gives me the right results, now that I'm trying it.
Thanks for taking the time to reply :)
Craig
On Tue, 16 Nov 2021 at 00:59, Even Rouault <even.rouault at spatialys.com> wrote:
> Craig,
> The sorting algorithm of the operations returned by projinfo is given at
> https://proj.org/operations/operations_computation.html#filtering-and-sorting-of-coordinate-operations
> The rationale is that, until you know exactly which point to transform,
> an operation whose area of use is larger than another one is a better
> default.
> But... if you use cs2cs or proj_trans() on the result of
> proj_create_crs_from_crs(), among the candidate operations, they will
> prefer the ones that can be instantiated (that is, in particular, whose
> grids are available) and that have a better accuracy.
> Did you actually try with cs2cs ? With your modified record,
> au_icsm_GDA94_GDA2020_conformal_and_distortion.tif is used for me when
> using -35 120 for example.
> $ echo -35 120 | PROJ_DEBUG=2 PROJ_NETWORK=ON PROJ_LIB=data src/cs2cs
> EPSG:4283 EPSG:7844
> pj_open_lib(proj.db): call fopen(data/proj.db) - succeeded
> pj_open_lib(proj.ini): call fopen(data/proj.ini) - succeeded
> Using coordinate operation GDA94 to GDA2020 (2)
> pj_open_lib(au_icsm_GDA94_GDA2020_conformal_and_distortion.tif): call
> fopen(data/au_icsm_GDA94_GDA2020_conformal_and_distortion.tif) - failed
> pj_open_lib(GDA94_GDA2020_conformal_and_distortion.gsb): call
> fopen(data/GDA94_GDA2020_conformal_and_distortion.gsb) - failed
> Using
> https://cdn.proj.org/au_icsm_GDA94_GDA2020_conformal_and_distortion.tif
> 34d59'59.951"S    120d0'0.037"E 0.000
> And if you add for example --bbox 120,-40,130,-30 to the projinfo
> invokation to restrict a bit the area of use, you should see the order
> you expect.
> Setting an operation accuracy to NULL / unknown makes it less prioritary
> than operations that have a known accuracy (point 6 of the above algorithm)
> Even
> Le 14/11/2021 à 21:31, Craig de Stigter a écrit :
> > Hey folks
> > We're trying to adjust proj to use a specific transformation between two
> > CRSes *by default* (ie. we don't want our calling software to have to be
> > explicit about which to use, since there are several places we're calling
> > PROJ from and we'd like to make them automatically consistent)
> > Stock proj 8.1.1 gives us these transform choices:
> >> $ PROJ_NETWORK=ON projinfo -s EPSG:4283 -t EPSG:7844 --spatial-test
> > intersects --summary
> >> Candidate operations found: 5
> >> EPSG:8048, GDA94 to GDA2020 (1), 0.01 m, Australia including Lord Howe Island, Macquarie Island, Ashmore and Cartier Islands, Christmas Island, Cocos (Keeling) Islands, Norfolk Island. All onshore and offshore.
> >> DERIVED_FROM(EPSG):8446, GDA94 to GDA2020 (3), 0.05 m, Australia - Australian Capital Territory; New South Wales; Northern Territory; Queensland; South Australia; Tasmania; Western Australia; Victoria.
> >> DERIVED_FROM(EPSG):8447, GDA94 to GDA2020 (2), 0.05 m, Australia - Australian Capital Territory; New South Wales; Northern Territory; Queensland; South Australia; Tasmania; Western Australia; Victoria.
> > The one we want is DERIVED_FROM(EPSG):8447, GDA94 to GDA2020 (2), which is
> > third in the list, and thus not chosen by default.
> > Aiming to bump that to the top of the list, we modified our proj.db build
> > to add this SQL:
> >> -- When transforming from GDA94 to GDA2020,
> >> -- use the distortion+conformal grid in preference to the conformal-only
> > grid.
> >> UPDATE grid_transformation
> >> SET accuracy = 0.0099
> >> WHERE auth_name = 'EPSG' AND code = 8447;
> > We expected this to bump the transform to the top of the list. It did bump
> > up by one slot, above the other grid-based transform (EPSG:8446). However,
> > it's still below the helmert transformation (EPSG:8048):
> > offshore.
> >> DERIVED_FROM(EPSG):8447, GDA94 to GDA2020 (2), 0.0099 m, Australia -
> > I couldn't find anything documenting that PROJ prefers Helmert transforms
> > over grid-based ones - merely that it prefers operations with defined
> > accuracy, and then prefers transforms in order of accuracy. In which case I
> > would have expected it to choose EPSG:8447 over EPSG:8048 now that we've
> > hacked the accuracy number.
> > Interestingly, setting the accuracy of the Helmert transform to NULL *did*
> > fix this:
> >> DERIVED_FROM(EPSG):8447, GDA94 to GDA2020 (2), 0.0499 m, Australia -
> >> EPSG:8048, GDA94 to GDA2020 (1), unknown accuracy, Australia including
> > and offshore.
> > So my questions are:
> > 1. Is setting the accuracy of EPSG:8048 to NULL a bad idea? We'll still
> > want to use EPSG:8048 as an offshore fallback.
> > 2. Any idea why PROJ is still prioritising EPSG:8048 after our first tweak?
> > 3. Is there a better way to accomplish this reprioritisation?
> > Thanks a bunch!
> http://www.spatialys.com
> My software is free, but my time generally not.
Regards,
Craig
Platform Engineer
Koordinates
+64 21 256 9488 / koordinates.com / @koordinates
More information about the PROJ mailing list
