[PROJ] Altitude question
Roger Oberholtzer roger.oberholtzer at gmail.com
Tue Nov 30 23:59:06 PST 2021
How does one determine the expected type of altitude (geoid or
ellipsoid) that a transformation expects? For example EPSG:5845
(Sweref99 + RH2000).
If I look at things like https://epsg.io/6499-cs or
https://epsg.io/5208 (which are referenced in the RH2000 definition)
the definition is not shown correctly in my browser. And I do not get
information for them via projinfo. It says the CRS is not found. Which
I guess is correct.
So, where do I look to see the expected type of altitude?
Roger Oberholtzer
More information about the PROJ mailing list
