[PROJ] New paper citing PROJ
Brenton R S Recht brstone at gmail.com
Sun Oct 3 18:00:15 PDT 2021
Hello all,
My paper "A variation on the Chamberlin trimetric map projection" was just
published in Cartography and Geographic Information Science:
https://www.tandfonline.com/doi/full/10.1080/15230406.2021.1975571 . If you
don't have institutional access, the preprint is on the GitHub repo linked
in the data availability statement. The paper heavily uses and refers to
PROJ, so I thought you all would be interested to hear about it.
The new map projection described in this paper was implemented as a patch
to PROJ. Would you be interested in including it? If so I can create a pull
request.
Brenton R S Recht
brsr.github.io
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211003/19c6d9f2/attachment.html>
More information about the PROJ mailing list
