[PROJ] Motion: adopt RFC 7
Kurt Schwehr schwehr at gmail.com
Thu Oct 7 12:54:40 PDT 2021
+1
I've was a happy user of the CMake config for Proj when I was doing a lot
of work with it a couple of years ago.
To echo the comment on bazel:
I have my own local bazel based build of Proj.  I don't see a reason for
the Proj project to need to do anything to support those of use who build
with bazel.  The cc_library rule is pretty much just "glob" calls
expressing where the srcs, hdrs, and textual_hders are to be found.  I
think bazel is not a good choice for the main Proj repo.
On Thu, Oct 7, 2021 at 9:09 AM Thomas Knudsen <knudsen.thomas at gmail.com>
wrote:
> +1
> tor. 7. okt. 2021 04.29 skrev Mike Taves <mwtoews at gmail.com>:
>> Hi all,
>> Even moves to adopt RFC 7 "Drop Autotools, maintain CMake"
>> https://lists.osgeo.org/pipermail/proj/2021-September/010360.html
>> https://github.com/OSGeo/PROJ/pull/2880
>> If approved, transition will commence in November 2021 (after PROJ 8.2
>> is released)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211007/7e4d82c1/attachment.html>
More information about the PROJ mailing list
