[PROJ] Transforming coordinates in C++
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Oct 29 04:49:38 PDT 2021
Thanks Even.
I see that proj_create takes a PJ_CONTEXT *ctx as the first argument. What
I have in C++ is a DatabaseContextPtr. Can I get a PJ_CONTEXT* from a
DatabaseContextPtr?
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Fri, 29 Oct 2021 at 12:17, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le 29/10/2021 à 12:00, Javier Jimenez Shaw a écrit :
> Hi
> Using C++ I am trying this: Given two CRSs, I would like to have access to
> the list of possible transformations (like with projinfo), and use those
> transformations to transform coordinates (like with cs2cs).
> Studying the code of projinfo, that uses mainly the C++ API, I already
> have a std::vector<CoordinateOperationNNPtr>. Nice, I can dump them in
> different formats.
> However, when I go to the code of cs2cs, I see that it is mainly using the
> C API.
> Is there any C++ equivalent to the function
> PJ_COORD proj_trans (PJ *P, PJ_DIRECTION direction, PJ_COORD coord);
> No.
> If you know which transformation you want to do, what you can easily do is
> exportToPROJString() it, and use proj_create() to instanciate it as a PJ*
> object you can use with proj_trans()
> That's more or less what proj_create_operations() + proj_list_get() do.
> Even
> Thanks.
> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211029/3976676d/attachment.html>
More information about the PROJ mailing list
