[PROJ] missing css in webpage
Joris Van den Bossche jorisvandenbossche at gmail.com
Thu Sep 16 23:56:36 PDT 2021
I took a quick look at it (it seems that the parent sphinx_rtd_theme is
just missing in the <head> tag, only the custom css overrides of proj
itself are included), and this might be triggered by the sphinx_rtd_theme
1.0 which was just released. Opened a PR that might fix it:
https://github.com/OSGeo/PROJ/pull/2858
Joris
On Fri, 17 Sept 2021 at 00:27, Mike Taves <mwtoews at gmail.com> wrote:
> On Fri, 17 Sept 2021 at 04:31, Javier Jimenez Shaw <j1 at jimenezshaw.com>
> wrote:
> > I just entered in https://proj.org/ , and the style looks... different.
> It looks like there are no styles / css loaded. Have we changed anything
> there?
> This issue is present with the HTML artifact from
> https://github.com/OSGeo/PROJ/actions/runs/1240806586
> (i.e. downloaded locally, open index.html)
> There are no obvious errors with the Docs/HTML job, so it might take a
> bit of investigation to find the error. Perhaps it is a new version of
> a sphinx component.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210917/68d40601/attachment.html>
More information about the PROJ mailing list
