[PROJ] detect missing grids in proj_create()
Martin Budaj m.b at speleo.sk
Wed Apr 6 07:42:05 PDT 2022
I use custom pipelines with proj_create() to get a precise direct
transformation between coordinate systems if proj_create_operations()
doesn't offer a transformation that is good enough.
If a transformation grid used in a pipeline is not found,
proj_create() fails. Is there a way to detect which grids are needed
for download? I can't use proj_coordoperation_get_grid_used() in this
case, as there is no coordoperation available.
Thanks,
Martin
More information about the PROJ mailing list
