[PROJ] Derived Vertical CRS
Even Rouault even.rouault at spatialys.com
Mon Aug 1 07:39:42 PDT 2022
> Regarding the WKT issue, I've raised this to the OGC CRS SWG list as
> the grammar of WKT doesn't allow currently a unitless parameter, even
> if the EPSG Vertical Offset and Slope method requires it. I'd suggest
> using something like UNIT["none",1] instead of
> ANGLEUNIT["arc-second",4.8481368111E-06], until that's cleared up
Got confirmation that requiring the unit was not intended and will be
amended in the next revision of the WKT CRS specification.
I've corrected the WKT parser to allow unit-less PARAMETER for
coordinate operations: https://github.com/OSGeo/PROJ/pull/3271
Even
http://www.spatialys.com
More information about the PROJ mailing list
