[PROJ] Proj9 small library size
Mike Taves mwtoews at gmail.com
Mon Aug 15 01:50:08 PDT 2022
On Mon, 15 Aug 2022 at 19:42, Patrick Elmer <proj at patrickelmer.de> wrote:
> I have just compiled Proj 9.0.1 on Linux. I am wondering that
> "libproj.so.25.9.0.1" has a sice of about 5M, whereas the one from Proj
> 8.2.1 is nearly 81M big.
I've noticed these differences for a while too. You can see it with
Debian distributions which show package and installed size:
- https://packages.debian.org/bullseye/libproj-dev - PROJ 7 via Autotools
- https://packages.debian.org/bookworm/libproj-dev - PROJ 9 via CMake
My observation is that autotools builds tend to take up more disk
space for C++ projects. (For comparison, see
https://packages.debian.org/buster/libproj-dev for PROJ 5 via
Autotools when it was a C-only library).
Hopefully someone has a better informed answer!
More information about the PROJ mailing list
