[PROJ] Proj9 small library size
Greg Troxel gdt at lexort.com
Tue Aug 16 05:03:58 PDT 2022
Even Rouault <even.rouault at spatialys.com> writes:
> @Mike That's a different thing. libproj-dev from PROJ 7 includes the
> static .a library, whereas the one from PROJ 9 doesn't (since PROJ
> CMake builds only build shared or static libraries, but not both at
> the same time)
That seems like a bug, if you can't easily pass a switch to make both.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220816/6216b772/attachment.sig>
More information about the PROJ mailing list
