[PROJ] PROJ and nadgrids vs hgridshift +grids
Even Rouault even.rouault at spatialys.com
Wed Aug 31 06:53:31 PDT 2022
+proj=hgridshift can also work on NTv2 .gsb files. Cf
https://proj.org/operations/transformations/hgridshift.html#cmdoption-arg-grids
Le 31/08/2022 à 15:41, David Fileccia a écrit :
> I need to get the grid shift of the NtV2 files for the Australian
> National Grid 1984. I can use the .TIF files in the PROJ data but I
> also need to be able to use the original GSB file for customers that
> only understand the official government data.
> My current setup for the .TIF file is:
> conststd::string p="+proj=pipeline"
> "+step+proj=unitconvert+xy_in=deg+xy_out=rad"
> "+step+proj=hgridshift+grids=<gridpath>.tif+inv"
> "+step+proj=unitconvert+xy_in=rad+xy_out=deg";
> I tried:
> "+step+nadgrids=<gridpath>.gsb+inv"
> Of course, this failed saying it is an invalid pipeline.
> What is the correct pipeline for this procedure?
> Best Regards,
> *David Fileccia*
> *Senior Systems Engineer | HEMISPHERE GNSS*
> Office: 6860 Little Twin Road, Germantown, OH 45327, USA
> Corporate: 8515 E. Anderson Drive, Scottsdale, AZ 85255, USA
> *M:* +1 404 579 4391
> dfileccia at hgnss.com <mailto:dfileccia at hgnss.com> | www.hgnss.com
> <http://www.hgnss.com/>
> *Disclaimer:*This message (including any other messages, attachments,
> or files within) contains information that may be confidential or
> privileged and is the property of Hemisphere GNSS, Inc. and its
> subsidiaries (‘Hemisphere’). It is intended for the person to whom it
> is addressed. If you are not the intended recipient, you are not
> authorized to read, copy, distribute, print, retain, or use this
> message or any part thereof. If you receive this message in error,
> please notify the sender immediately and delete all copies of this
> message. Any opinions or views expressed within are solely those of
> the author and do not necessarily represent those of Hemisphere. Thank
> you for your cooperation.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220831/02045e9b/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220831/02045e9b/attachment.png>
More information about the PROJ mailing list
