[PROJ] PROJ 9.1.1RC1 & PROJ-data 1.12RC1
Kristian Evers kristianevers at gmail.com
Thu Dec 1 00:45:05 PST 2022
With +1s from myself, Even, Howard and Charles the motion is passed.
I’ll start preparing the final releases. Expect an announcement within the next couple of hours.
/Kristian
> On 30 Nov 2022, at 23.04, Charles Karney <charles.karney at gmail.com> wrote:
> +1
> On 11/30/22 15:58, Kristian Evers wrote:
>> Apart from a minor detail in the release notes no issues with the release
>> candidates has been reported, so I hereby motion they are promoted
>> to final releases.
>> I’ll start with my +1.
>> /Kristian
>>> On 25 Nov 2022, at 18.56, Kristian Evers <kristianevers at gmail.com> wrote:
>>> All,
>>> I’ve prepared release candidates for PROJ 9.1.1 and PROJ-data 1.12. The PROJ
>>> release includes a number of bug fixes (release notes below) and a slight update
>>> to the database. PROJ-data is extended with the at_bev_AT_GIS_GRID_2021_09_28
>>> grid.
>>> Download the archives here:
>>> https://download.osgeo.org/proj/proj-9.1.1RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-9.1.1RC1.zip
>>> https://download.osgeo.org/proj/proj-data-1.12RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-data-1.12RC1.zip
>>> As always, please test the release candidates and report your findings
>>> either here on the mailing list on in the issue tracker on GitHub.
>>> /Kristian
>>> 9.1.0 Release Notes
>>> Updates
>>> o Database: register at_bev_AT_GIS_GRID_2021_09_28 grid (#3442)
>>> Bug fixes
>>> o Implement alterGeodeticCRS and stripVerticalComponent for DerivedProjected (#3482)
>>> o Various improvements to handling of DerivedProjectedCRS
>>>   (#3482, #3477, #3342, #3319, #3317)
>>> o Add missing <cstdint> includes (#3459)
>>> o cs2cs: better validate value of -W option (#3453)
>>> o DatabaseContext::lookForGridInfo(): fix caching of filenames and set
>>>   correct URLs (#3448)
>>> o Database: register in grid_alternatives grids from PROJ-data that have no
>>>   corresponding transformation record (#3446)
>>> o cass projection: fix forward computation of easting (#3433)
>>> o Implement Geographic/Vertical Offset conversions (#3413)
>>> o vandg projection: handle +over to extend the validity domain outside of
>>>  |lon|>180deg (#3427)
>>> o eqdc projection: avoid floating point division by zero in non-nominal case (#3415)
>>> o createOperations(): fix issues when transforming between Geog3D and
>>>   DerivedGeog3D CRS with Geographic3D offsets method (#3411)
>>> o VerticalCRS::_isEquivalentTo(): do not consider VerticalCRS and
>>>   DerivedVerticalCRS as equivalent (#3408)
>>> o cct and cs2cs: Avoid problems when encountering UTF-8 BOM characters at
>>>    beginning of input files (#3395)
>>> o createFromUserInput(): Improved lookup when approximate name is provided (#3371)
>>> o projinfo / cs2cs : auto promotion to 3D of CRS specified by name (#3367)
>>> o findsOpsInRegistryWithIntermediate(): make it work when source/target geodetic
>>>   CRS has no known id (#3365)
>>> o createOperations(): emulate PROJ < 6 behavior when doing geocentric <-->
>>>   geographic transformation between datum with unknown transformation (#3361)
>>> o Fix issue when transforming from/into a WKT2 Bound VerticalCRS with a
>>>   'Geographic3D to GravityRelatedHeight' method (#3355)
>>> o proj_normalize_for_visualization(): take into account FORCE_OVER property
>>>   from source operation (#3350)
>>> o Link geodtest against libm when available (#3341)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> Charles Karney <charles at karney.com>
> 702 Prospect Ave
> Princeton, NJ 08540-4037
More information about the PROJ mailing list
