[PROJ] How to get started with CRS in WKT?
Even Rouault even.rouault at spatialys.com
Mon Dec 5 04:46:42 PST 2022
Jochem,
Is "read the spec", the answer you expected ;-) ? I'm afraid that's the
best I have: http://docs.opengeospatial.org/is/18-010r7/18-010r7.html
Regarding indentation, don't worry about that. Write your WKT as you can
in a file and then use "projinfo @your.wkt", and it will return a nicely
reformatted string. But you need to get brackets right, otherwise the
parser will be lost.
You may also try the PROJJSON encoding as an input and feed it to
"projinfo @your.json" and it will return a WKT, but I'm not sure it will
help you, as it is more oriented to be machine friendly.
For CRS definitions themselves, it is unlikely you can use the
transformation constructs if you intend to have your CRS in EPSG.
ABRIDGEDTRANSFORMATION is only for BoundCRS, and they are none of them
in EPSG. GEOGTRAN is a Esri WKT specific thing. COORDINATETRANSFORMATION
is for a standalone CoordinateTransformation object
If your ultimate goal is to provide CRS and coordinate transformations
to EPSG, then you don't need to create WKT. Go to
https://epsg.org/dataset-change-requests.html and click on the "Template
for data submission" link at the right of the page, and you'll get an
Excel spreadsheet where you'll get a form with the decomposition of the
objects.
Even
Le 05/12/2022 à 13:03, Lesparre, Jochem via PROJ a écrit :
> Dear PROJ maillist,
> At a the national mapping agency of the Netherlands we are responsible
> for defining the CRS of European Netherlands and the 3 islands of the
> Caribbean Netherlands. We are working on standardising the official
> transformations so these can be added to EPSG and the transformations
> become available in PROJ and other software. To perform
> transformations ourself, we create cct pipelines. I love the power cct
> pipelines. Unfortunately, other applications often expect a WKT
> string. For the transformations we added to EPSG, I can copy-paste the
> WKT from epsg.org. To experiment with a custom CRS, I sometimes try to
> create my own WKT strings. However, these attempts are not very
> successful for two reasons.
> Firstly, it takes an annoying lot of effort get the code indented to
> make it readable (the indent plugin in notepad++ only works after
> using search and replace to add line breaks) and to keep the brackets
> right for valid WKT while editing, before I can even start to
> experiment with the rest of the syntax. /Can you recommend a way to
> make creating WKT easier?/
> Secondly, I am quite confused by the different WKT examples that I
> find. Some seem to use different ways to define transformations in WKT
> (e.g. ABRIDGEDTRANSFORMATION, GEOGTRAN, COORDINATEOPERATION). /Can you
> recommend a way to get started with understanding WKT?/ As a
> geodesist, I am familiar with transformation methods, so I only need
> information on how to translate between this theory and WKT.
> Kind regards, Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor
> de geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene
> leveringsvoorwaarden van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed.
> If you are not the intended recipient, you are notified that
> disclosing, copying, distributing or taking any action in reliance on
> the contents of this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products
> and services
> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221205/aa13daab/attachment-0001.htm>
More information about the PROJ mailing list
