[PROJ] Correcting metadata in GeoTIFF files
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Fri Jan 28 04:08:34 PST 2022
Hi Even,
Thanks for the quick and clear reply. I now found the description for this use case at proj.org, which explicitly mentions the naptrans grid of the Netherlands as example (sorry for not RTFM). I have some remaining questions, though:
  *   Why is this use case not more common? This [1] was the standard way to get a transformation to a national compound CRS in PROJ4, right?
  *   Since the CRS of the GeoTIFF is the source-crs [2], does this mean that other software will would show the grid values at the latlon of the source-crs instead of at the latlon of the interpolation-crs?
Additional question on names and aliases:
  *   For EPSG:4289, the EPSG registry uses the name “Amersfoort”. However, we (the official authority of this CRS) never use this name. Since the name “Amersfoort” has been in EPSG for a long time, EPSG preferred not to correct this, but to add the official name “RD Bessel” as an alias in the EPSG registry. Can I use the official alias “RD Bessel” instead of the EPSG name “Amersfoort” for the WKT strings and/or the description in the metadata of the Geodetic TIFF Grids?
Regards, Jochem
[1] PROJ4-style transformation to national compound CRS of the Netherlands:
cs2cs +init=epsg:4937 +to +proj=sterea +lat_0=52.156160556 +lon_0=5.387638889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +nadgrids=rdtrans2018.gsb +units=m +geoidgrids=naptrans2018.gtx +vunits=m +no_defs
[2] Result of gdalinfo:
Driver: GTiff/GeoTIFF
Files: naptrans2018.tif
Size is 301, 481
Coordinate System is:
GEOGCRS["ETRF2000",
    DATUM["European Terrestrial Reference Frame 2000",
        ELLIPSOID["GRS 1980",6378137,298.257222101,
            LENGTHUNIT["metre",1]]],
    PRIMEM["Greenwich",0,
        ANGLEUNIT["degree",0.0174532925199433]],
    CS[ellipsoidal,3],
        AXIS["geodetic latitude (Lat)",north,
            ORDER[1],
        AXIS["geodetic longitude (Lon)",east,
            ORDER[2],
        AXIS["ellipsoidal height (h)",up,
            ORDER[3],
            LENGTHUNIT["metre",1]],
    USAGE[
        SCOPE["Geodesy."],
        AREA["Europe - onshore and offshore: Albania; Andorra; Austria; Belgium; Bosnia and Herzegovina; Bulgaria; Croatia; Cyprus; Czechia; Denmark; Estonia; Faroe Islands; Finland; France; Germany; Gibraltar; Greece; Hungary; Ireland; Italy; Kosovo; Latvia; Liechtenstein; Lithuania; Luxembourg; Malta; Moldova; Monaco; Montenegro; Netherlands; North Macedonia; Norway including Svalbard and Jan Mayen; Poland; Portugal; Romania; San Marino; Serbia; Slovakia; Slovenia; Spain; Sweden; Switzerland; United Kingdom (UK) including Channel Islands and Isle of Man; Vatican City State."],
        BBOX[32.88,-16.1,84.73,40.18]],
    ID["EPSG",7931]]
Data axis to CRS axis mapping: 2,1,3
Origin = (1.990000000000000,56.006250000000001)
Pixel Size = (0.020000000000000,-0.012500000000000)
Metadata:
  area_of_use=European Netherlands including EEZ of the North Sea
  AREA_OR_POINT=Point
  interpolation_crs_wkt=GEOGCRS[Amersfoort,DATUM[Amersfoort,ELLIPSOID[Bessel 1841,6377397.155,299.1528128,LENGTHUNIT[metre,1,ID[EPSG,9001]],ID[EPSG,7004]],ID[EPSG,6289]],CS[ellipsoidal,2,ID[EPSG,6422]],AXIS[latitude (Lat),north],AXIS[longitude (Lon),east],ANGLEUNIT[degree,0.0174532925199433,ID[EPSG,9102]],ID[EPSG,4289]]
  target_crs_epsg_code=5709
  TIFFTAG_COPYRIGHT=Nederlandse Samenwerking Geodetische Infrastructuur (NSGI). Creative Commons Attribution 4.0 International licence https://creativecommons/licenses/by/4.0/
  TIFFTAG_DATETIME=2022:01:28 00:00:00
  TIFFTAG_IMAGEDESCRIPTION=ETRF2000 (EPSG:7931) to NAP height (EPSG:5709). Converted from naptrans2018.gtx (last modified at 2019/03/22)
  TYPE=VERTICAL_OFFSET_GEOGRAPHIC_TO_VERTICAL
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (   1.9900000,  56.0062500) (  1d59'24.00"E, 56d 0'22.50"N)
Lower Left  (   1.9900000,  49.9937500) (  1d59'24.00"E, 49d59'37.50"N)
Upper Right (   8.0100000,  56.0062500) (  8d 0'36.00"E, 56d 0'22.50"N)
Lower Right (   8.0100000,  49.9937500) (  8d 0'36.00"E, 49d59'37.50"N)
Center      (   5.0000000,  53.0000000) (  5d 0' 0.00"E, 53d 0' 0.00"N)
Band 1 Block=301x6 Type=Float32, ColorInterp=Gray
  Description = geoid_undulation
  Unit Type: metre
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220128/0f501c19/attachment-0001.html>
More information about the PROJ mailing list
