[PROJ] Affine transformation using DERIVEDPROJCRS
Bart.Duijndam at ziggo.nl Bart.Duijndam at ziggo.nl
Tue Jul 5 14:35:50 PDT 2022
Hi Even,
Thanks for your help; you’re working late…
Please be advised that I already started with using nn_dynamic_pointer_cast<ProjectedCRS>(crs);
But then I got the following obscure error message:
D:\Source\VS19\PROJ\test\unit\test_crs.cpp(5516): error C2280: 'dropbox::oxygen::nn<osgeo::proj::crs::ProjectedCRSPtr>::nn(PtrType)': attempting to reference a deleted function
          with
              PtrType=osgeo::proj::crs::ProjectedCRSPtr
  D:\Source\VS19\PROJ\include\proj\nn.hpp(126): note: see declaration of 'dropbox::oxygen::nn<osgeo::proj::crs::ProjectedCRSPtr>::nn'
  D:\Source\VS19\PROJ\include\proj\nn.hpp(126): note: 'dropbox::oxygen::nn<osgeo::proj::crs::ProjectedCRSPtr>::nn(PtrType)': function was explicitly deleted
          with
  ninja: build stopped: subcommand failed.
Build All failed.
So that’s why I tried ProjectedCRSNNPtr instead
Cheers,
Bart
Sent: Tuesday, 5 July 2022 23:30
To: Bart.Duijndam at ziggo.nl; proj at lists.osgeo.org
Subject: Re: [PROJ] Affine transformation using DERIVEDPROJCRS
    auto proj_crs = nn_dynamic_pointer_cast<ProjectedCRSNNPtr>(crs);
==> auto proj_crs = nn_dynamic_pointer_cast<ProjectedCRS>(crs);
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220705/4aa74469/attachment.htm>
More information about the PROJ mailing list
