[PROJ] Affine transformation using DERIVEDPROJCRS
Even Rouault even.rouault at spatialys.com
Fri Jul 8 13:29:17 PDT 2022
Bart,
> ** RE-SENT AS PLAIN TEXT IN VIEW OF EMAIL SIZE **
> Hi Even,
> I worked things through, and have included the following three routines in test_crs.cpp, that compile and test okay.
> I have a few questions / remarks though:
> 1. Why is the EPSG definition ID of an affine transform not being exported:  ID["EPSG",9624]],
You need to add it to the PropertyMap with
.set(metadata::Identifier::CODESPACE_KEY, metadata::Identifier::EPSG)
  .set(metadata::Identifier::CODE_KEY, 9624)
> 2. Same for the ID’s of the Affine transformation parameters: 8623, 8624, 8625, 8639, 8640 and 8641.
Similarly as above on the property map of each parameter.
> 3. The USAGE description isn’t being included in the generated WKT string and is also missing in the derived transform
>     USAGE[
>     SCOPE["Engineering survey, topographic mapping."],
>     AREA["Netherlands - onshore, including Waddenzee, Dutch Wadden Islands and 12-mile offshore coastal zone."],
>     BBOX[50.75,3.2,53.7,7.22]]]
> This is really a pity. Is there an ‘easy’ way to fix this ?
There's no reason that a DerivedProjectedCRS should have the same usage
as its base one.
You can re-use the one of the base CRS (the projected CRS) with
something along
propertyMap.set(ObjectUsage::OBJECT_DOMAIN_KEY, baseCRS->domains()[0]);
If you want to build a custom objectDomain object, the best example
would be to look at the JSONParser::buildObjectDomain() implementation
in src/iso19111/operation/oputils.cpp
where propertyMap is the first argument of
DerivedProjectedCRS::create(), on which you'll also call
.set(IdentifiedObject::NAME_KEY, "Abtswoudsebrug")
> 4. Nevertheless, maybe the example below is more ‘meaningful’ than the current one, that is included in the test_crs.file.
Those unit tests are just that, unit tests, so they indeed tend to be
minimalist.
Perhaps a good contribution would be an Example section under
https://proj.org/development/index.html
Even
> Kind regards,
> Bart
> ProjectedCRSNNPtr createProjected_v2()
>      auto dbContext = DatabaseContext::create();
>      auto factory = AuthorityFactory::create(dbContext, "EPSG");
>      auto crs = factory->createCoordinateReferenceSystem("28992");
>      auto proj_crs = nn_dynamic_pointer_cast<ProjectedCRS>(crs);
>      EXPECT_TRUE(proj_crs != nullptr);
>      return NN_CHECK_ASSERT(proj_crs);
> static DerivedProjectedCRSNNPtr createDerivedProjectedCRS_v2() {
>      auto derivingConversion = Conversion::create
>          PropertyMap().set(IdentifiedObject::NAME_KEY, "Affine"),
>          PropertyMap().set(IdentifiedObject::NAME_KEY, "Affine parametric transformation"),
>          std::vector<OperationParameterNNPtr>
>              OperationParameter::create(PropertyMap().set(
>                  IdentifiedObject::NAME_KEY, "A0")),
>                  IdentifiedObject::NAME_KEY, "A1")),
>                  IdentifiedObject::NAME_KEY, "A2")),
>                  IdentifiedObject::NAME_KEY, "B0")),
>                  IdentifiedObject::NAME_KEY, "B1")),
>                  IdentifiedObject::NAME_KEY, "B2")),
>          std::vector<ParameterValueNNPtr>
>              ParameterValue::create(Length(-257762.015)),
>              ParameterValue::create(Scale ( 0.914845326707141)),
>              ParameterValue::create(Scale ( 0.403804443019272)),
>              ParameterValue::create(Length(-374179.972)),
>              ParameterValue::create(Scale (-0.403804443019272)),
>      // create a DerivedProjectedCRS, but ...
>      // first we need to get the BaseCRS from an EPSG code.
>      return DerivedProjectedCRS::create(
>          PropertyMap().set(IdentifiedObject::NAME_KEY, "Abtswoudsebrug"),
>          createProjected_v2(), derivingConversion,
>          CartesianCS::createEastingNorthing(UnitOfMeasure::METRE));
> TEST(crs, derivedProjectedCRS_WKT2_2019_v2) {
>      auto expected_v2 =
>          "DERIVEDPROJCRS[\"Abtswoudsebrug\",\n"
>          "    BASEPROJCRS[\"Amersfoort / RD New\",\n"
>          "        BASEGEOGCRS[\"Amersfoort\",\n"
>          "            DATUM[\"Amersfoort\",\n"
>          "                ELLIPSOID[\"Bessel 1841\",6377397.155,299.1528128,\n"
>          "                    LENGTHUNIT[\"metre\",1]]],\n"
>          "            PRIMEM[\"Greenwich\",0,\n"
>          "                ANGLEUNIT[\"degree\",0.0174532925199433]]],\n"
>          "        CONVERSION[\"RD New\",\n"
>          "            METHOD[\"Oblique Stereographic\",\n"
>          "                ID[\"EPSG\",9809]],\n"
>          "            PARAMETER[\"Latitude of natural origin\",52.1561605555556,\n"
>          "                ANGLEUNIT[\"degree\",0.0174532925199433],\n"
>          "                ID[\"EPSG\",8801]],\n"
>          "            PARAMETER[\"Longitude of natural origin\",5.38763888888889,\n"
>          "                ID[\"EPSG\",8802]],\n"
>          "            PARAMETER[\"Scale factor at natural origin\",0.9999079,\n"
>          "                SCALEUNIT[\"unity\",1],\n"
>          "                ID[\"EPSG\",8805]],\n"
>          "            PARAMETER[\"False easting\",155000,\n"
>          "                LENGTHUNIT[\"metre\",1],\n"
>          "                ID[\"EPSG\",8806]],\n"
>          "            PARAMETER[\"False northing\",463000,\n"
>          "                ID[\"EPSG\",8807]]]],\n"
>          "    DERIVINGCONVERSION[\"Affine\",\n"
>          "        METHOD[\"Affine parametric transformation\"],\n"
>          "        PARAMETER[\"A0\",-257762.015,\n"
>          "            LENGTHUNIT[\"metre\",1,\n"
>          "                ID[\"EPSG\",9001]]],\n"
>          "        PARAMETER[\"A1\",0.914845326707141,\n"
>          "            SCALEUNIT[\"unity\",1,\n"
>          "                ID[\"EPSG\",9201]]],\n"
>          "        PARAMETER[\"A2\",0.403804443019272,\n"
>          "        PARAMETER[\"B0\",-374179.972,\n"
>          "        PARAMETER[\"B1\",-0.403804443019272,\n"
>          "        PARAMETER[\"B2\",0.914845326707141,\n"
>          "                ID[\"EPSG\",9201]]]],\n"
>          "    CS[Cartesian,2],\n"
>          "        AXIS[\"(E)\",east,\n"
>          "            ORDER[1],\n"
>          "        AXIS[\"(N)\",north,\n"
>          "            ORDER[2],\n"
>          "                ID[\"EPSG\",9001]]]]";
> //        "    USAGE[\",\n"
> //        "        SCOPE[\"Engineering survey, topographic mapping.\"],\n"
> //        "        AREA[\"Netherlands - onshore, including Waddenzee, Dutch Wadden Islands and 12-mile offshore coastal zone.\"],\n"
> //        "        BBOX[50.75, 3.2, 53.7, 7.22]]]";
>      auto crs = createDerivedProjectedCRS_v2();
>      EXPECT_EQ(
>          crs->exportToWKT(
>              WKTFormatter::create(WKTFormatter::Convention::WKT2_2019).get()), expected_v2);
>      EXPECT_TRUE(crs->isEquivalentTo(crs.get()));
>      EXPECT_TRUE(crs->shallowClone()->isEquivalentTo(crs.get()));
>      EXPECT_FALSE(crs->isEquivalentTo(createUnrelatedObject().get()));
>      auto geodCRS = crs->extractGeodeticCRS();
>      EXPECT_TRUE(geodCRS != nullptr);
http://www.spatialys.com
More information about the PROJ mailing list
