[PROJ] Could you please explain me why I can't project RDN2008 (EPSG:6706) to ERTF2000 (EPSG:9067) or ITRF2000 (EPGS:8997)
Even Rouault even.rouault at spatialys.com
Thu Jul 21 10:37:07 PDT 2022
> That said in the database, ETRS89 is modeled as a datum ensemble of
> the many ETRFxxxx realizations, so potentially PROJ could use that
> information to infer a null transformation between ETRS89 and ETRF2000
> with the accuracy of the datum ensemble (here 0.1 m) (we actually do
> that manually for the WGS 84 datum ensemble vs its realizations, but
> that should be generalized), and chain that together with the RDN2008
> to ETRS89 transformation.
I've implemented that per https://github.com/OSGeo/PROJ/pull/3266. So
now you get
> $ projinfo -s RDN2008 -t ETRF2000
> Candidate operations found: 1
> Operation No. 1:
> unknown id, RDN2008 to ETRS89 (1) + ETRS89 to ETRF2000, 0.1 m, Italy -
> onshore and offshore; San Marino, Vatican City State.
> PROJ string:
> +proj=noop
> Even
> Le 19/07/2022 à 03:02, Giacomo Cappellini a écrit :
>> Hello,
>> I'm generally new to working with CRS different from EPSG:4326 + UTM
>> and I'm facing some issues while trying to use RDN2008, which is the
>> official reference system for Italy at current date.
>> Please excuse me if the question sounds trivial to experts, but I
>> can't figure out why there are no non-ballpark operations to go
>> from/to RDN2008 and ETRF2000 or ITRF2000.
>> Afaik, RDN2008 is ETRS89 realization ETRF2000 epoch 2008.0.
>> Proj Rel. 8.2.1, January 1st, 2022
>>     $ projinfo -s EPSG:6706 -t EPSG:9067 --spatial-test intersects
>>     --grid-check none --hide-ballpark --summary
>>     Candidate operations found: 0
>>     $ projinfo -s EPSG:6706 -t EPSG:8997 --spatial-test intersects
>> Thanks
>> G.C.
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220721/61c0d109/attachment.htm>
More information about the PROJ mailing list
