[PROJ] Derived Vertical CRS
Javier Jimenez Shaw j1 at jimenezshaw.com
Sun Jul 31 04:11:36 PDT 2022
Thank you Even.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Sat, 30 Jul 2022 at 19:35, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> I've addressed this in https://github.com/OSGeo/PROJ/pull/3270.
> Regarding the WKT issue, I've raised this to the OGC CRS SWG list as the
> grammar of WKT doesn't allow currently a unitless parameter, even if the
> EPSG Vertical Offset and Slope method requires it. I'd suggest using
> something like UNIT["none",1] instead of
> ANGLEUNIT["arc-second",4.8481368111E-06], until that's cleared up
> Even
> Le 29/07/2022 à 21:16, Javier Jimenez Shaw a écrit :
> Hi
> Thanks to Even's PR #3200 "Implement Vertical Offset and slope
> transformation method", I am trying to use a Derived Vertical CRS using the
> conversion method "Vertical Offset and Slope" (that will be a perfect
> combination with "Affine parametric transformation" in the horizontal... I
> hope)
> The WKT2 I have created is this
> VERTCRS["Custom Vertical",
>     BASEVERTCRS["EGM2008 height",
>         VDATUM["EGM2008 geoid"]],
>     DERIVINGCONVERSION["vertical offs. and slope",
>         METHOD["Vertical Offset and Slope",
>             ID["EPSG",1046]],
>         PARAMETER["Ordinate 1 of evaluation point",46.9166666666669,
>             ANGLEUNIT["degree",0.0174532925199433],
>             ID["EPSG",8617]],
>         PARAMETER["Ordinate 2 of evaluation point",8.18333333333361,
>             ID["EPSG",8618]],
>         PARAMETER["Vertical Offset",-0.245,
>             LENGTHUNIT["metre",1],
>             ID["EPSG",8603]],
>         PARAMETER["Inclination in latitude",-0.21,
>             ID["EPSG",8730]],
>         PARAMETER["Inclination in longitude",-0.032,
>             ID["EPSG",8731]],
>         PARAMETER["EPSG code for Horizontal CRS",4326,
>             ID["EPSG",1037]]],
>     CS[vertical,1],
>         AXIS["gravity-related height (H)",up,
>             LENGTHUNIT["metre",1]],
>     USAGE[
>         SCOPE["unknown"],
>         AREA["World"],
>         BBOX[-90,-180,90,180]]]
> The first strange thing is that without the unit in the parameter "EPSG
> code for Horizontal CRS", projinfo "$(cat derived_vertical.wkt)" shows a
> warning:
> Warning: Parsing error : syntax error, unexpected ID. Error occurred
> around:
>             ID["EPSG",1037]]],
> When I try to see how the conversion would be with the command
> projinfo -s EPSG:3855 -t "$(cat derived_vertical.wkt)"
> I get
> PROJ string:
> Error when exporting to PROJ string: Unsupported conversion method:
> Using it in a compound crs and using cs2cs does not get the proper
> transformation neither.
> Am I creating the WKT2 string properly to create a derived vertical crs
> (to be used in a compound) with that conversion method?
> Thanks
> PS. I am using master from today
> PS2.  projinfo -s EPSG:5728 -t EPSG:5730 shows a coordinate operation
> that uses "Vertical Offset and Slope", with a nice PROJ string
> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220731/28bb79a3/attachment.htm>
More information about the PROJ mailing list
