[PROJ] cmake find_package() fails to find PROJ6 installed with MacPorts
Tom O'Reilly oreilly at mbari.org
Wed Jun 1 12:55:31 PDT 2022
Thanks Even.
My project needs proj6, but as a test of cmake I installed proj9 with MacPorts - and find_package(Proj9 CONFIG REQUIRED) fails just as before.
Question - if the installed proj9 provides CONFIG support, I presume there is a proj9-config.cmake or Proj9Config.cmake file somewhere. Where would I look for this file? I see /opt/local/lib/proj9 - but the file is not in there. Would this file be in there if proj9 supports CONFIG mode or is there some other place to look?
Thanks
Tom
Thomas C. O'Reilly
Monterey Bay Aquarium Research Institute
7700 Sandholdt Road
Moss Landing, California 95039-9644
831-775-1766 (voice)
831-775-1620 (FAX)
oreilly at mbari.org (email)
http://www.mbari.org (World-wide Web)
"The machine does not isolate us from the great mysteries
of nature, but plunges us more deeply into them."
- ANTOINE DE SAINT-EXUPERY
"Wind, Sand, and Stars" (1939)
From: "Even Rouault" <even.rouault at spatialys.com>
To: "Tom O'Reilly" <oreilly at mbari.org>, "proj" <proj at lists.osgeo.org>
Sent: Wednesday, June 1, 2022 11:39:55 AM
Subject: Re: [PROJ] cmake find_package() fails to find PROJ6 installed with MacPorts
Tom,
You should try to use a more recent version than PROJ 6.x (not sure what "proj6" corresponds to in MacPorts). I believe PROJ Config support was only added in PROJ > 6, or can only be relied upon in those later versions
Even
Le 01/06/2022 à 20:29, Tom O'Reilly a écrit :
I'm running cmake 3.22.4 on MacOS 11.6.
I installed proj6 with "sudo port proj6" which looks to be [ https://proj.org/install.html | the proj-recommended way to
                        install with MacPorts ] . I see the proj6 include/ and lib/ subdirectories in /opt/local/lib/proj6, and set PROJ6_ROOT to /opt/local/lib/proj6 accordingly in my applications's CMakeLists.txt.
But CmakeLists.txt is unable to find proj on the system. The [ https://proj.org/development/cmake.html | proj page
                          also says ] :
The recommended way to use the PROJ library in a CMake project is to link to the imported library target PROJ::proj provide by the CMake configuration which comes with the library. Typical usage is:
find_package(PROJ CONFIG REQUIRED)
However find_package() cannot find PROJ or PROJ6 on my system - find_package() exits with this message:
CMake Error at CMakeLists.txt:95 (find_package):
Could not find a package configuration file provided by "PROJ6" with any of
the following names:
PROJ6Config.cmake
proj6-config.cmake
Moreover I do not see any files named "proj*.cmake" in /opt/local - somehow installing proj6 with MacPorts did not include this package information? What am I doing wrong?
Any help much appreciated!
Thanks
Tom
Thomas C. O'Reilly
7700 Sandholdt Road
831-775-1620 (FAX)
[ mailto:oreilly at mbari.org | oreilly at mbari.org ] (email)
[ http://www.mbari.org/ | http://www.mbari.org ] (World-wide Web)
PROJ mailing list [ mailto:PROJ at lists.osgeo.org | PROJ at lists.osgeo.org ] [ https://lists.osgeo.org/mailman/listinfo/proj | https://lists.osgeo.org/mailman/listinfo/proj ]
-- [ http://www.spatialys.com/ | http://www.spatialys.com ] My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220601/64eb2323/attachment.htm>
More information about the PROJ mailing list
