[PROJ] PROJ 9.0.1RC2 & PROJ-data 1.10RC1
Kristian Evers kristianevers at gmail.com
Wed Jun 8 10:50:03 PDT 2022
All,
I have prepared release candidates for PROJ 9.0.1 and PROJ-data 1.10. Due to a slight
hiccup with PROJ 9.0.0RC1 before it was announced we are going more or less straight
to RC2 as to not disturb those who managed to download it right away. The PROJ release
notes can be found at the bottom of this email.
The PROJ-data package includes a metadata correction for some Dutch grids and adds
a Norwegian transformation grid as an extension to the NKG transformations.
Download the release candidates here:
https://download.osgeo.org/proj/proj-9.0.1RC2.tar.gz
https://download.osgeo.org/proj/proj-9.0.1RC2.zip
https://download.osgeo.org/proj/proj-data-1.10RC1.tar.gz
https://download.osgeo.org/proj/proj-data-1.10RC1.zip
As always, please report any issues you find in the release candidates either here or
on GitHub.
/Kristian
9.0.1 Release Notes
 Database updates
 o Update to EPSG 10.064 (#3208)
 o Add OGC:CRS84h (WGS 84 longitude-latitude-height) (#3155)
 Bug fixes
 o Use CMAKE_INSTALL_MANDIR to override default (#3081)
 o Increase MAX_ITER so Mollweide forward projection works near the poles (#3082)
 o Fix wrong results with SQLite 3.38.0 (#3091)
 o Fix issue when transforming from/to BoundCRS of 3D CRS with non-Greenwhich
  prime meridian, created from WKT (#3098)
 o Fix issues with WKT of concatenated operations (#3105)
 o CMake: fix installation of proj.pc on Windows (#3109)
 o createOperations(): fix issue in transformation northing, easting
   projected CRS -> +proj=longlat +lon_wrap (#3110)
 o unitconvert: round to nearest date when converting to yyyymmdd (#3111)
 o Fix comparison of GeodeticRefrenceFrame vs DynamicGeodeticReferenceFrame (#3120)
 o createOperations(): fix transformation involving CompoundCRS, ToWGS84
   and PROJ4_GRIDS (#3124)
 o Fix datum names when importing from PROJ4 crs strings (affects some
   transformations using geoidgrids) (#3129)
 o Deal with PARAMETER["EPSG code for Interpolation CRS",crs_code] (#3149)
 o createOperations(): fix CompoundCRS[BoundCRS[ProjectedCRS],BoundCRS[VerticalCRS]]
   to Geog3DCrs (#3151)
 o ITRF2014: fix ITRF2014:ITRF88,ITRF94 and ITRF96 definitions (#3159)
 o createBoundCRSToWGS84IfPossible(): improve selection logic to generate +towgs84=
   taking into account extent (#3160)
 o createOperations(): fix some complex cases involving TOWGS84 and CompoundCRS (#3163)
 o Fix cmake CURL dependency, update appveyor - vcpkg interaction (#3185)
 o WKT import: deal with Projected CRS that is a mix of WKT1:GDAL / WKT1:ESRI (#3189)
 o createOperations(): fix/improve result of 'BD72 + Ostend height ' to 'WGS84+EGM96 height' (#3199)
 o Identifier::isEquivalentName(): fix when ending by ' + ' which could indirectly cause
   an infinite stack call in master (#3202)
 o WKT import: correctly deal with absence of Latitude_Of_Origin parameter in
   WKT1 ESRI with Stereographic projection (#3212)
 o PROJJSON parser: do not error out if a datum ensemble member is unknown in the database (#3223)
More information about the PROJ mailing list
