[PROJ] PROJ 9.0.1 & PROJ-data 1.10
Kristian Evers kristianevers at gmail.com
Wed Jun 15 07:47:05 PDT 2022
On behalf of the PROJ development team I am happy to announce the
release of PROJ 9.0.1 and PROJ-data 1.10.
The PROJ release includes a number of bug fixes and a few updates to
the database. See the release notes below for details.
The PROJ-data package includes a metadata correction for some Dutch grids and adds
a Norwegian transformation grid as an extension to the NKG transformations.
Download the new packages here:
https://download.osgeo.org/proj/proj-9.0.1.tar.gz
https://download.osgeo.org/proj/proj-9.0.1.zip
https://download.osgeo.org/proj/proj-data-1.10.tar.gz
https://download.osgeo.org/proj/proj-data-1.10.zip
/Kristian
9.0.1 Release Notes
 Database updates
 o Update to EPSG 10.064 (#3208)
 o Add OGC:CRS84h (WGS 84 longitude-latitude-height) (#3155)
 Bug fixes
 o Use CMAKE_INSTALL_MANDIR to override default (#3081)
 o Increase MAX_ITER so Mollweide forward projection works near the poles (#3082)
 o Fix wrong results with SQLite 3.38.0 (#3091)
 o Fix issue when transforming from/to BoundCRS of 3D CRS with non-Greenwich
  prime meridian, created from WKT (#3098)
 o Fix issues with WKT of concatenated operations (#3105)
 o CMake: fix installation of proj.pc on Windows (#3109)
 o createOperations(): fix issue in transformation northing, easting
   projected CRS -> +proj=longlat +lon_wrap (#3110)
 o unitconvert: round to nearest date when converting to yyyymmdd (#3111)
 o Fix comparison of GeodeticRefrenceFrame vs DynamicGeodeticReferenceFrame (#3120)
 o createOperations(): fix transformation involving CompoundCRS, ToWGS84
   and PROJ4_GRIDS (#3124)
 o Fix datum names when importing from PROJ4 crs strings (affects some
   transformations using geoidgrids) (#3129)
 o Deal with PARAMETER["EPSG code for Interpolation CRS",crs_code] (#3149)
 o createOperations(): fix CompoundCRS[BoundCRS[ProjectedCRS],BoundCRS[VerticalCRS]]
   to Geog3DCrs (#3151)
 o ITRF2014: fix ITRF2014:ITRF88,ITRF94 and ITRF96 definitions (#3159)
 o createBoundCRSToWGS84IfPossible(): improve selection logic to generate +towgs84=
   taking into account extent (#3160)
 o createOperations(): fix some complex cases involving TOWGS84 and CompoundCRS (#3163)
 o Fix cmake CURL dependency, update appveyor - vcpkg interaction (#3185)
 o WKT import: deal with Projected CRS that is a mix of WKT1:GDAL / WKT1:ESRI (#3189)
 o createOperations(): fix/improve result of 'BD72 + Ostend height ' to 'WGS84+EGM96 height' (#3199)
 o Identifier::isEquivalentName(): fix when ending by ' + ' which could indirectly cause
   an infinite stack call in master (#3202)
 o WKT import: correctly deal with absence of Latitude_Of_Origin parameter in
   WKT1 ESRI with Stereographic projection (#3212)
 o PROJJSON parser: do not error out if a datum ensemble member is unknown in the database (#3223)
More information about the PROJ mailing list
