[PROJ] grid shift with GDA2020
Pierre Chaponniere pierrechapo at gmail.com
Wed Jun 29 12:58:46 PDT 2022
Dear Proj community,
i am looking at transforming data into GDA2020 MGA zone 54 :
+proj=utm +zone=54 +south +ellps=GRS80 +units=m +no_defs +type=crs
But it seems this projection is associated with a transformation grid
https://www.icsm.gov.au/datum/gda-transformation-products-and-tools/transformation-grids
I have therefore dowloaded the corresponding .gsb transformation files
https://github.com/icsm-au/transformation_grids
However when I apply the transformation, it appears the process does not
use the transformation files and generate data with planimetric and
vertical offsets.
How can I make sure the transformation grid are applied and what file makes
the link between proj code and transformation files - is this stored in
proj.db ?
Thanks for your help !
Best regards,
Pierre C
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220629/90f10428/attachment.htm>
More information about the PROJ mailing list
