[PROJ] Equirectangular/Equidistant Cylindrical
Even Rouault even.rouault at spatialys.com
Wed Nov 2 08:51:03 PDT 2022
Andrew,
did you include https://github.com/OSGeo/gdal/pull/6523 in your GDAL
build ? It will be included in the soon-to-be-released GDAL 3.6.0
release candidate
Even
Le 02/11/2022 à 16:40, Andrew Patterson a écrit :
> Hello again!
> I was not expecting to return to this issue (I found the actual cause
> of my original problem, a semi-transposed transform matrix) but after
> fixing the original bug a new issue cropped up and it ended up
> explaining (I think) the error message:
> ERROR 1: PROJ: proj_create_from_database: crs not found
> I get the same error internally when I attempt to import that PDF
> using the EPSG code instead of the WKT. This seems to be because the
> EPSG code is an ESRI-flavour ESPG code 102422. It attempts to do a
> lookup using the "EPSG" factory in PROJ and the SQL statement:
> "SELECT type FROM crs_view WHERE auth_name = ? AND code = ?" (from
> factory.cpp:5216 in PROJ)
> It fails because it uses 'EPSG' for auth_name, but 'ESRI' causes it to
> succeed. If I update ogrspatialreference.cpp (circa 10635):
> auto obj = proj_create_from_database(d->getPROJContext(),
>                                          "EPSG",
>                                          osCode.c_str(),
>                                          PJ_CATEGORY_CRS,
>                                          true,
>                                          nullptr);
> Replacing:
> "EPSG"
> with:
> nCode > 100000 ? "ESRI" : "EPSG"
> After this, it successfully imports the coordinate system. That feels
> skeevy to me, but maybe using importFromEPSG() is the wrong function
> to use? Though I don't see an alternative. I'm 99% sure this worked in
> a previous version of GDAL, though it may have required a call to
> morphFromESRI().
> Am I doing something wrong or is there something missing that should
> handle ESRI EPSG codes?
> As usual, any help is greatly appreciated!
> On Thu, Oct 13, 2022 at 9:38 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Access to the PDF to try spotting the cause of the
>     "proj_create_from_database: crs not found" error & possibly
>     solving it
>     would still be interesting
>     Le 13/10/2022 à 15:31, Andrew Patterson a écrit :
>     > Even,
>     > So while I was writing up the issue I realized I could probably
>     > provide some simple code to help illustrate the problem, so I wrote
>     > some. Then I realized I should really run it in our old app as
>     well,
>     > which took a while -- which is why you're reading this today rather
>     > than yesterday. But in the course of doing this, I basically proved
>     > that PROJ is fine, so there's no reason to create the issue. So
>     false
>     > alarm!
>     > Plotting on the maps is a two step process; coordinate transform
>     via
>     > PROJ from WGS84 to the map's projection, then run that coordinate
>     > through a world-to-page (i.e. pixel) transform. The latter is
>     *really*
>     > easy to test so that's always the first thing I verify. Once that's
>     > been done, the problem basically has to lie with the PROJ
>     transform --
>     > and this has been true until now. I'm actually quite perplexed. If
>     > both parts of a two-part transformation are fine, why is everything
>     > shifted? Something is hinky, but that's my problem not yours, so I
>     > apologize for wasting your time with this. I think I also jumped
>     the
>     > gun because of problems with Equidistant Cylindrical in the
>     past, but
>     > for once, that project is innocent.
>     > Again, sorry for the trouble!
>     http://www.spatialys.com
>     My software is free, but my time generally not.
> Andrew Patterson
> Lead Software Architect
> Avenza Systems Inc.
> email: andrew at avenza.com
> phone: 416.487.5116
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221102/d4833b21/attachment.htm>
More information about the PROJ mailing list
